查看: 1887|回复: 0
红星新品预告(7319)-1/72 苏霍伊 Su-57战斗机完整板件图
发表于 2019-8-24 17:25:41 | 显示全部楼层 |阅读模式
vMQWpXxp3JU.jpg rDOHr7zjH2g.jpg ul89lxIpKEY.jpg cLzsYAF9P6U.jpg EoQkGLowogA.jpg ZZakp34YLMQ.jpg 7UzbynttKoU.jpg EVnm-imEzUU.jpg ix5zKihs5Xo.jpg xa6qYU3hZfY.jpg
Friends!
Our colleague and well-known master of "sushko-building" Pavel Rebezov begins to work on our upcoming novelty - the Model Su-57 on a scale of 1/72.
The word to the author:
Welcome!
As a prologue to the upcoming assembly, a small overview of the sprues of the upcoming novelty from the Star - Su-57 on a 72 scale.
And so, plastic is completely new, to the previous model T-50 has nothing to do.
In general, there are not so many Litnikovs. The fuselage is made of two halves, along with wing consoles and part of mechanization.
Next is a sprue with keels and horizontal stabilizers, deflected elements of the root influx, air intakes, elements and sash of the chassis niches, cabin, chassis racks and various trifles. It should be noted that horizontal stabilizers and deflected elements of the influx can now be done in two variants, in a neutral and in a rejected position.
Next are two identical sprues with nozzle parts, elements of external suspension, including missiles R-77 and R-73, outboard fuel tanks and pnevmatics, as well as there are parts that set the position of the drives of horizontal stabilizers. Nozzles can also be made in two variants, direct and rejected.
Speaking of nozzles, saw-shaped edge kind of hints - psss, guy, do not want to put the product 30? Well, those who prefer a more realistic option with the AL-100 nozzle, will be able to supply tar products from the same Armata or other producers of the aftermarket.
Transparent sprue with lantern details, ANS lens, ILS and landing, now fashionable, LED headlights. Cast well, there are no defects on the lantern, and I would like to note a more logical output of feeders, unlike the Lantern Su-27UB/Su-30SM for example.
On this directly on the sprues Su-57 all.
Then there are the last three splys, two of which are already familiar with the sets of MiG-29SMT and Su-30SM, with elements of weapons. Well, the third, with most likely already the Admiral-Admiral of the space fleet, is rooted in the first model of the T-50.
Decal, at the time of receipt of the plastic, has not yet been printed, so it will be announced most likely later, in the process of construction.
Друзья!
Наш коллега и известный мастер "сушкостроения" Pavel Rebezov приступает к работе над нашей грядущей новинкой - моделью Су-57 в масштабе 1/72.
Слово автору:
Приветствую!
В качестве пролога к предстоящей сборке, небольшой обзор на литники грядущей новинки от Звезды - Су-57 в 72 масштабе.
И так, пластик абсолютно новый, к предыдущей модели Т-50 отношения не имеющий.
Литников в общем, по факту, не так уж и много. Фюзеляж выполнен из двух половинок, вместе с консолями крыла и частью механизации.
Далее идет литник с килями и горизонтальными стабилизаторами, отклоняемыми элементами корневого наплыва, каналами воздухозаборников, элементами и створками ниш шасси, кабиной, стойками шасси и различной мелочевкой. Нужно отметить, что горизонтальные стабилизаторы и отклоняемые элементы наплыва, теперь можно сделать в двух вариантах, в нейтральном и в отклоненном положении.
Следом идут два одинаковых литника с деталями сопел, элементами внешней подвески, включая ракеты Р-77 и Р-73, подвесными топливными баками и пневматиками, а так же присутствуют детали, которые задают положение приводов горизонтальных стабилизаторов. Сопла так же можно сделать в двух вариантах, прямое и отклоненное.
Кстати, о соплах, пилообразная кромка как бы намекает - пссс, парень, не хочешь поставить изделие 30? Ну а те, кто предпочтет более реалистичный вариант с соплом АЛ-100, смогут поставить смоляные изделия от той же Арматы или других производителей афтемаркета.
Прозрачный литник с деталями фонаря, линзой ОЛС, ИЛС и посадочными, ныне модными, светодиодными фарами. Отлит неплохо, дефектов на фонаре нет, и хочется отметить более логичный вывод питателей, в отличии от фонаря Су-27УБ/Су-30СМ например.
На этом непосредственно по литникам Су-57 все.
Далее идут последние три литника, два из которых знакомы уже по наборам МиГ-29СМТ и Су-30СМ, с элементами вооружения. Ну а третий, со скорее всего уже генерал-адмиралом космофлота, уходит корнями аж к первой модели Т-50.
Декаль, на момент получения пластика, еще не была напечатана, по этому ее покажу скорее всего позже, в процессе постройки.​​​​
GMT+8, 2024-12-1 00:15
