查看: 1738|回复: 0
Dora Wings新品预告(DW72009)-1/72 费尔雷 德尔塔2建模
发表于 2019-8-13 19:32:46 | 显示全部楼层 |阅读模式
”Dear friends.
We finally returned to work on a project that was started a long time ago - the legendary FD.2. Yes, this moment the 3D model looks like this.
Your opinion..?”
The Fairey Delta 2 was the first jet aircraft to exceed 1000 mph in level flight. Or as the Fairey publicity department stated “flying faster than the sun moves across the sky”. It is a design also noticeable for its droop nose similar to Concorde.
GMT+8, 2025-2-21 03:40
