查看: 1742|回复: 0
Airfix新品预告(A05135)-1/48 超马林 喷火 FR Mk.XIV成品
发表于 2019-5-15 18:56:28 | 显示全部楼层 |阅读模式
h_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_on_the_airfix_workben.jpg j_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg k_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg l_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg m_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg n_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg o_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg p_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg r_airfix_rolls_royce_griffon_powered_spitfire_mkxiv_a05135_build_images_on_the_a.jpg
Airfix product designer Paramjit is also a keen modeller and he recently had the opportunity to build the A scheme from the new 1/48th scale Spitfire FR Mk.XIV kit – this exclusive series of pictures show the fruits of his labours.
For the first time, we are able to show built models finished in both of the scheme options which are available with the new Rolls-Royce Griffon powered Spitfire FR Mk.XIV kit.
Release date should be sometime this month.Spitfire FR Mk.XIV
GMT+8, 2024-11-27 20:29
