查看: 1957|回复: 0
Clearprop Models新品(CP72004)-1/72 图波列夫 图-143"航程"无人侦察机
发表于 2019-5-3 12:55:35 | 显示全部楼层 |阅读模式
IMG_7297.jpg 6285190408_.jpg 6290190408_.jpg 6293190408_.jpg 6295190408_.jpg 6297190408_.jpg 6299190408_.jpg 6302190408_.jpg 6306190408_.jpg 6312190408_.jpg 6315190408.jpg 6318190408_.jpg 6319190408_.jpg
10.50欧元This kit is designed for advanced modellers. It is fully equipped with various accessories that
will help you to improve the final result - to create a copy of this unmanned reconnaissance
aircraft that will repeat the original as much as possible.
There are 3 versions of model assembling:
1) in flight with a JATO booster on display stand;
2) on the chassis;
3) on the transporting cart
In any of these three options, you can use either the nose equipped with the film cameras or TV
cameras payload of your choice.
Markings are provided for four different schemes.
Colored and detailed assembly guide will allow you to build this elegant model in one breath and
decorate your exposition.
https://clearpropmodels.com/tu-143-reys-shop
GMT+8, 2025-3-2 15:22
