The Weekend was not wasted and the test assembly of the new Su-30CM in scale 1/72 in the performance of Alexander Fomin is coming to an end!
Friends!
Our colleague Pavel Rebezov, known for his excellent models of aircraft family Su, begins to assemble our new model Su-30SM.
Paul's Word:
A small review of the Litnikov of the upcoming novelty.
There Are four new Litnik in the set. The Rest are already familiar with the sets of Su-27SM, Su-27UB, on this on them to emphasize especially I will not, but on the new would be more detailed.
On the first liter, it is given in black color, there are wing consoles, keel, front horizontal plumage, wing socks, chassis bow stand, brake guard, front niche chassis and horizontal stabilizer drives. It is Necessary to note, that flperons now are given separate details, as well as actuators of stabilizers, and both in two variants, in the rejected parking and in the cleaned in zero.
The Second and third Litniki are the upper and lower half of the fuselage. The Upper half, similar to the Su-33 model, is made in one detail, in contrast to the Su-27SM and Su-27UB models.
On the fourth Litnik it is possible to observe details of air intakes, basic niches of a chassis, flperons as I have already noted above, in two variants of configuration, and nozzles of engines. The Last can also be collected in two versions, in the rejected state, and No.
The Rest of the Litniki migrated from the Su-27UB/27CM sets. These are sprat with stabilizers, chassis racks, cockpit elements and weapons, to which also added 4 frames from the set of Mig-29SMT, as well as a sprat with transparent details of the lantern.
The Decal is quite rich in elements, and in addition to the boards of the VKS RF and MA NAVY, allows to assemble the AIR force of Kazakhstan. There are 5 options.
Друзья!
Наш коллега
Pavel Rebezov, известный своими отличными моделями самолетов семейства Су, приступает к сборке нашей новой модели Су-30СМ.
Слово Павлу:
Небольшой обзор литников грядущей новинки.
В наборе идет четыре новых литника. Остальные уже знакомы по наборам Су-27СМ, Су-27УБ, по этому на них акцентироваться особо не буду, а вот на новых остановлюсь поподробнее.
На первом литнике, он дан черным цветом, присутствуют консоли крыла, кили, переднее горизонтальное оперение, носки крыла, носовая стойка шасси, тормозной щиток, передняя ниша шасси и приводы горизонтальных стабилизаторов. Стоит отметить, что флапероны теперь даны отдельными деталями, как и приводы стабилизаторов, причем и те и другие в двух вариантах, в отклоненном стояночном и в убранном в ноль.
Второй и третий литники представляют из себя верхнюю и нижнюю половины фюзеляжа. Верхняя половина, по аналогии с моделью Су-33, выполнена одной деталью, в отличии от моделей Су-27СМ и Су-27УБ.
На четвертом литнике можно наблюдать детали воздухозаборников, основных ниш шасси, флапероны, как я уже отметил выше, в двух вариантах конфигурации, и сопла двигателей. Последнии так же можно собрать в двух вариантах, в отклоненном состоянии, и нет.
Остальные литники перекочевали из наборов Су-27УБ/27СМ. Это литники со стабилизаторами, стойками шасси, элементами кабины и вооружением, к которому так же добавили 4 рамки из набора МиГ-29СМТ, а так же литник с прозрачными деталями фонаря.
Декаль достаточно богата на элементы, и помимо бортов ВКС РФ и МА ВМФ, позволяет собрать борт ВВС Казахстана. Всего 5 вариантов.
