查看: 1987|回复: 0
爱德美新品预告(12620)-1/144 罗克韦尔B-1B枪骑兵轰炸机试模
发表于 2019-1-31 12:57:10 | 显示全部楼层 |阅读模式
The Academy will release the 1/144 scale B1 Lancer Air Force bomber in early 2019. This product is developed as a MCP and has a lot of snap-in implementations. Here we will look at the time of injection of this product. The injection color of the full product will probably be the same dark gray as the actual color.
The 1/144 scale is a large gas, but the product size is about 30cm. The size is similar to the 1/72 f-15k. The MCP product was developed with easy assembly in mind, but the detail is not very short.
The panel lines are uniformly and sharply reproduced. The division of the upper and lower parts allows the junction line to be organized into a panel line, minimizing the removal of joint lines. Air intake Upper Junction is a structure that covers separate parts and does not cause joint lines.
Variable IK structure is reproduced well. The wing angle is an optional expression.
With the investment of new equipment, the depth and breadth of the panel lines are consistently fragmented.
These days, the academy seems to be divided. The tail part is plump.
During the injection, there is oil and a soot.
The bay can reproduce the open and closed state.
The bomb inside the bay is made with a simple structure, given its scale.
MMZ20190126172047_2_14.jpg MMZ20190126172047_2_15.jpg MMZ20190126172047_2_16.jpg MMZ20190126172048_2_17.jpg
White-injected landing gear. In mass production, the runner is white. MCP is called, but there are two colors, gray and white. The raw gas is so...
Transparent parts do not have a good taste yet, so transparency is off.
MMZ20190126172045_2_3.jpg MMZ20190126172044_2_0.jpg MMZ20190126172044_2_1.jpg MMZ20190126172045_2_2.jpg MMZ20190126172048_2_18.jpg
This product is expected to be released in the first half of 2019 and expects consumers to be the opposite of 20,000 USD.
GMT+8, 2024-11-27 15:43
