查看: 1694|回复: 0
Arma Hobby新品预告(70018)-1/72 霍克飓风Mk.I更新
发表于 2018-11-20 15:36:16 | 显示全部楼层 |阅读模式
ah-70019-web-1.jpg HURRICANE-TEST-06.jpg HURRICANE-TEST-07.jpg HURRICANE-TEST-08.jpg HURRICANE-TEST-09.jpg HURRICANE-TEST-10.jpg HURRICANE-TEST-04.jpg HURRICANE-TEST-03.jpg HURRICANE-TEST02.jpg HURRICANE-TEST-01.jpg 70019-instr-01.jpg 70019-instr-02.jpg 70019-instr-03.jpg 70019-instr-04.jpg 70019-instr-05.jpg 70019-instr-06.jpg 70019-instr-07.jpg 70019-instr-08.jpg 70019-hurricane-web-768x532.jpg 70019-blacha-hurricane-mkI-300x220.jpg 70019-hurricane-web-detal.jpg
Preparations for launching the Hawker Hurricane Mk I model in the 1/72 scale have almost reached the end. On the last Friday, the first test shots were made. See how the details came out and share your opinion with us.
The first injections are always a trip to unknown. At the beginning it goes reluctantly, the parts usually do not cast well. Testing the various settings of the injection moulding machine with error recording takes some time. Then a few corrections to the plastic inlets, parts revision and subsequent rehearsals. This is how the next week of work will look like. If everything goes as planned, we hope to launch sales next week. The models would be dispatched  at the beginning of December. Let’s go to see the most raw injections, before the corrections.
The model was built from test shots. Not all parts were coming out the way we wanted, not everything was filling up properly. The assembly goes without problems. The fitting of parts is user-friendly.
The advantages of the model are delicate panel lines, clearly better than in the P.11c model kit. The imitation of canvas on the fuselage and control surfaces came out very well. In my opinion it is better than in other 1/72 scale Hurricane models. Surface is rich with details like subtle round latches (dzuses) and raised rivets. There will be where to make washes and test weathering tricks!
The interior of the undercarriage bay has well-developed Hurricane look and the cockpit has a level of detail proper for 1/48 scale. The main wheels are cast as weighted, and the inscription “Dunlop” is reproduced.
After carefully looking at all the parts we found only a few things to improve in the model. The bottom of the radiator has a bit too thick panel  lines and a slightly asymmetrically outlined outlet flap. We plan to electro-drill them “clean” with a copper electrode again. The radiator will then be approx. 0.15mm deeper and the part more symmetrical. This will not affect the assembly, because the mating surface is on the other side. We also have to “draw” canopy rails – two raised parallel lines on each side to be done by simple milling. On the left engine cover a subtle ridge appeared during electro drilling, hopefully it will be reduced.
In my opinion, after examination of the test injections, it looks like we have a detailed, well-fitting Hurricane Mk I 1/72 scale model that is easy to assemble. A few small fixes and the model goes on sale! How many Hurricanes do you plan to build?
ARMA Hobby
GMT+8, 2024-11-27 11:36
