查看: 17521|回复: 2
[陆军装备] [开盒简评]红星/ZVEZDA(3681)-1/35 俄国重型步兵战车T-15"Armata"开盒
发表于 2018-10-21 15:06:28 | 显示全部楼层 |阅读模式
Friends!
Today we want to please you with a review on the fresh and long-awaited novelty of the national star-the Russian heavy combat vehicle Infantry tbmp T-15  "armature " in scale 1/35 and on our bonuses from the Pre-order kit!
This model was announced more than a year ago and since then has been a laborious process of its creation. The prototype amazed the size and the memorable appearance on parades and forum  "Army ". And in the beginning of October the model appeared on the shelves.
Despite the base  "Armats" from the Model T-14 there was only one pair of litnik, and everything else-a new development. The model depicts a machine with a boomerang-bm combat module.
The box is standard for star-soft color box with dense box of thick cardboard inside. The front side of the box is decorated with a spectacular picture, and the back side shows an example of a model test assembly.
Items are packaged in several packages, decals, nylon mesh, and transparent sprat are packaged in an individual package.
Instruction in the signature style of the stars, clear, but rather tightly-lined. According to the new tradition of the company painting schemes are given on the color liner, with the instructions of flowers on the palette of Master Akril and Tamiya.
Variants of colouring as though two, on a parade car and a fictional camouflage board. But the decal is given six sets of numbers, which gives a large selection of possible options for the design of the model.
The decal itself is printed by the company  "Hippo " and is of good quality, although judging by the reviews in the network sometimes there is a shift of colors. This is a marriage that is worth writing to a firm, asking for a replacement decal.
The grid on the MTO is traditionally for the star is proposed to be made of Kappronova Setochki. This misunderstanding is corrected by our set of photopoisoning)
In a package with a decal and a grid there are also transparent details. All optics and viewing devices are made of transparent plastic, which complements the model well.
And the most interesting-castings.
The set contains 7 Litnikov of grey plastic and two separate castings of the case. The grey plastic pleasant in work, moderately soft, well glued and processed.
Problems with casting, in the form of small ducklings and underlivs we found only on the front part of the top part of the case. Still, the star is not perfectly given such large castings. There is no detail on the details, seams from joints of a mould are small and will not interfere with work. The pushers are almost everywhere on the inside of the parts, only on the long branches of the truck they go to the outside. And then they will hide under the rollers.
Model detailing is excellent. Very pleased (in spite of the small flaws of casting) the top and their hull, cast in one detail. And from the abundance of details on the Litniki run eyes. The bolts on the body and on the rolls, welded seams on the boards of the tower, etc. look good. Only cables that are thin and almost without relief look bad.
The truck is similar to the Armata T-14, semi-patterned.
The whole set makes a great impression. Good detailing, attention to detail, large model size, interesting prototype.
The model will serve as an excellent choice for both novice and professional.
And of course we will not forget about our bonuses!
All customers who pre-order have received a set with our additions in the form of photopoisoning, metal trunks of guns and machine gun, composition  "anti-slip " and coupon for 10% discount on all subsequent orders within a month.
Consider these bonuses in more detail.
In photopoisoning are given lattices on MTO, protective lattices on boards and covers on ptrk  "Kornet ". The photopoisoning itself is made of brass, and in the package is covered with a protective film, which must be removed before starting work. To photopoisoning there is an instruction available on our site.
Guns and machine gun replace native parts. In the case of the barrel of the gun is replaced only the tip of the barrel with a muzzle brake, because the casing of the trunk of the square shape and well cast in plastic. Under the installation of our bonus will need to cut a part of the native part and drill the recess under the base of the barrel in it.
Features and method of application  "Antilime " are described in detail in a separate post: https://vk.com/wall-114983756_34708
And participants of the club  "armature " get additional bonuses!
Metal rope, tape 30mm shells and electro-magnetic trawl!
Metal cables are placed in the place of the native parts. Under their installation it is necessary to cut off plastic kokushi from native ropes and to drill them for installation of metal parts. The length of the ropes should be measured by plastic parts.
The tape of 30mm shells can be different, one of five types with the photo. Otstreljannoj or equipped with different shells.
Electro-magnetic trawl replaces the native plastic parts and is made of a pleasant in the work of molded plastic. It is enough simply to cut out its details from a litnik, to paint and to install on a model.
And of course a couple of words about the sets of additions to the model, which can be purchased separately.
The module AY-220 m is made by our colleagues from DVC and is distinguished by excellent detailing. With him the model is transformed and looks brutal!
Material-molded plastic. To glue with super-glue, it is easy processed. Instructions-on the site and in the kit.
Rollers for the "armatists" (T-14, T-15) are intended to replace the native parts. They have better detailing, elaborate bolts and rubber rim. The material is the same molded plastic.
To summarize, I want to thank the star for the excellent model of this huge and formidable combat vehicle!
Well, we tried to make this set more interesting and attractive!
https://vk.com/armatamodels?w=wall-114983756_35131
1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg 15.jpg 16.jpg 17.jpg 18.jpg 19.jpg 20.jpg 21.jpg 22.jpg 23.jpg 24.jpg 25.jpg 26.jpg 27.jpg 28.jpg 29.jpg 30.jpg 31.jpg 32.jpg 33.jpg 34.jpg 35.jpg 36.jpg 37.jpg 38.jpg 39.jpg 40.jpg 41.jpg 42.jpg 43.jpg 44.jpg 45.jpg 46.jpg 47.jpg 48.jpg 49.jpg 50.jpg 51.jpg 52.jpg 53.jpg 54.jpg 55.jpg 56.jpg 57.jpg 58.jpg 59.jpg 60.jpg 61.jpg 62.jpg 63.jpg 64.jpg 65.jpg 66.jpg
以下是Armata会员预定版赠送品
67.jpg 68.jpg 69.jpg 70.jpg 71.jpg 72.jpg 73.jpg 74.jpg 75.jpg 76.jpg 77.jpg 78.jpg 79.jpg 80.jpg 81.jpg 82.jpg 83.jpg 84.jpg 85.jpg 86.jpg 87.jpg 88.jpg 89.jpg 90.jpg 91.jpg 92.jpg 93.jpg 94.jpg 95.jpg 96.jpg 97.jpg 98.jpg 99.jpg 100.jpg 101.jpg 102.jpg 103.jpg 104.jpg 105.jpg 106.jpg 107.jpg 108.jpg 109.jpg 110.jpg 111.jpg 112.jpg 113.jpg 114.jpg 115.jpg 116.jpg 117.jpg 118.jpg 119.jpg 120.jpg 121.jpg 122.jpg 123.jpg 124.jpg 125.jpg 126.jpg
发表于 2018-11-14 09:55:33 | 显示全部楼层
长见识啦。moxing论坛真强大
发表于 2020-9-15 11:36:18 | 显示全部楼层
       这初回特典版真好啊
GMT+8, 2025-5-31 14:40
