查看: 1169|回复: 0
Ammo-Mig新品-万圣节色彩限定套装
发表于 2018-10-7 21:19:01 | 显示全部楼层 |阅读模式
Just to halloween, this limited set is perfect for your demons, ghosts, witches, skeletons, monsters, Spiders and all the other creepy creatures in the afterlife..
As always, paints are designed to be used with brush or airbrush... And at this terrible delightful time of year, also with a witch's broom!
PS: the use of this set for embalming and adding to the pot with poison is forbidden, even if you feel an irresistible temptation!
GMT+8, 2024-11-30 18:44
