查看: 3109|回复: 0
全球首发 | 小号手4K51“防线”SSC-3岸防导弹系统模型登陆SIME 2016
发表于 2016-6-20 14:18:03 | 显示全部楼层 |阅读模式
2016820-22,一场模型行业的豪华盛典即将点燃上海滩夏日的激情。已经报名参展第十三届“SIME上海模型展”的企业超过150家。展位销售持续火热进行中!
中山雅太(小号手)将在今年的SIME上海模型展”现场进行4K51“防线”SSC-3岸防导弹系统模型的全球首发!
4K51“防线”SSC-3岸防导弹系统 抢先看
4K51“防线”SSC-3岸防导弹系统曾经广泛出口到其他国家。3P51的发射车以MAZ-543M8×8底盘为基础,使用KT-161型双联装发射筒。两个雷达结构存在。早期型使用搜索和制导一体雷达,也用在舰船上。后期型号使用3 Ts25 EGarpun E雷达,工作在X波段,频段第0.812吉赫,使用的无源探测系统和等幅工作方式,可以达到0.5-1.5度的精度。
RussianSSC-3/4K51 Rubezh Costal Defence System 3P51M Missile Launcher
The4K51 Rubezh / SSC-3 coastal defence system was also very widely exported. The3P51 TELAR is based on the MAZ-543 8 x 8 chassis, and uses a trainableelevating two round launcher with a unique KT-161 launch tube design. Two radarconfigurations exist. Export systems are typically equipped with the sameSquare Tie search and fire control radar as fitted to corvettes and fastmissile boats. Late models employed the 3Ts25E Garpun E targeting system, whichcombines an X-band radar component with a passive targeting system whichoperates between 0.8 and 12 GHz against pulsed and CW emitters, with anaccuracy of 0.5 - 1.5°.
展位销售持续火热进行中!
现在就联系我们,抢占数量有限的展出席位吧!
GMT+8, 2025-2-18 19:58
