查看: 3468|回复: 4
SH新品预告-2022年纽伦堡新品
发表于 2022-2-11 19:10:45 | 显示全部楼层 |阅读模式
SA35008 Panzerbefehlswagen 35(t)         1/35
SA35009 Panhard 178B ‘47 mm Gun Late Turret’   1/35
SA72017 Sleuch Slepper      1/72
SA72027 Captured Sd.Kfz 250      1/72
SA72028 Rheinbote German WWII tactical ground to ground V4 Rocket 1/72
SH32083 Fiat G.50B Bicomando   1/32
SH32084 Manshu Ki-79 ‘Japanese Trainer’             1/32
SH48053 Breda Ba 65A-80              1/48  Re-issue
SH48160 Baltimore Mk.I/II            1/48
SH48200 SNCAC NC.701 Martinet              1/48
SH48202 AH-1G Cobra     1/48
SH48205 Reggiane Re.2000 III. Serie         1/48
SH48207 SIAI-Marchetti SF.260AM/M/W               1/48
SH48210 Heinkel He 177 A-3         1/48
SH48211 Avro Anson Mk.I             1/48
SH48212 Siebel Si 204E ‘German Night Bomber & Trainer’             1/48
SH48216 AJ-37 Viggen ‘Strike Fighter’      1/48
SH48217 Aero C-3B ‘Czechoslovak Bomber-Trainer’         1/48
SH48218 L-4 Grasshopper              1/48
SH48219 Bugatti 100 Racer            1/48
SH48220 J-3 Cub              1/48
SH48221 Potez 631            1/48   New Tool
SH72075 CH-37 Mojave   1/72   Re-issue
SH72162 Short Sunderland Mk.V 'Fighting Commies in Europe and the Far East' 1/72 Re-issue
SH72291 Mirage F.1B       1/72       Re-issue
SH72336 Sea Vixen FAW Mk.I/II 1/72                       Re-issue
SH72352 Mirage IIIC         1/72
SH72406 Piaggio P.108B ‘Quadrimotore’ 1/72       Re-issue
SH72415 Vautour IIB ‘French Jet Bomber’             1/72
SH72425 Hudson Mk.IV/V/VI       1/72                       New Tool
SH72436 Curtiss CW-21   1/72                       New Tool
SH72438 Short Sunderland Mk.I/II ‘Flying Porcupine’       1/72
SH72445 Tachikawa Ki-54Otsu / Hickory ‘ Gunner Trainer’             1/72
SH72448 Junkers Ju 87D-5 ‘Axis Satellites’             1/72
SH72450 AT-6B/C/D/F/G Texan  1/72
SH72452 DH. Mosquito PR Mk.XVI            1/72
SH72457 Bugatti 100P      1/72
SH72458 Junkers Ju 87D-5/N/D-8 ‘Night Attack Stukas’   1/72
SH72460 P-70 Nighthawk               1/72
SH72462 Messerschmitt Bf 109E-Trop/E-7 Trop   1/72
SH72463 Gloster Meteor Mk.8/9 IAF        1/72
SH72471 Blue bird on a long flyight over Europe, Africa and Asia (Aero 11 L-BUCD)           1/72 SN72007                Kriegsfischkutter             1/72
SH72152 Fairey Albacore Mk.I     1/72                       New Tool
So what do we have here? A nice little family of the Aero A-11/12 biplanes in 1/72 scale, the first of which should see the light of day sometimes this June - in the form of the Aero A-11 of škpt. Stanovský and mechanic Šimek with which we would like to commemorate the anniversary of their long distance flight. We hope you like the rendered images, for now the A-11 military version.
 楼主| 发表于 2022-2-11 19:11:59 | 显示全部楼层
Day Two of our Nuremberg Online. What we want to boast about now is the coming sets - both the resin cast and the 3D-printed ones. Start looking for wheel sets for 1/72 Beaufort, 1/72 Airfix's Mosquito as well as the same planes' as produced by Tamiya and Hasegawa (these two latter just really need to differ from the former set), then for the Lancaster in both scales, even further another 3D printed Volkssturm firing arms set plus some more equipment and armament for Wehrmacht in 1/35 scale. The coming months will also see the release of exhausts sets for 1/72 Wellington Mk.II, Mosquito and 1/48 Lancaster. Our 1/32 AH-1G Cobra model kit will get a few more detailing sets, too.
XM_195_1.png v8fuky_wellington.png V8fuky.png Set_2_plánek.png Set_2_4.png Set_2_3.png Set_2_2.png Set_2_1.png Mosquito_v8fuky_1_72_Airfix.png Mosquito_1_72_Tamiya_hasegawa_2.png Mosquito_1_72_Airfix.png Laffly_kola_3.png Laffly_kola_2.png L3.png L1.png kola_wellington.png F2.png 1_72.png 1_48.png 1 Bristol.png
 楼主| 发表于 2022-2-11 19:12:49 | 显示全部楼层
Each ‘proper’ Nuremberg fair, we have always provided you with a plenty of information on the new releases. Let's do not make any exception now just because of the cancellation of the fair. The kits mentioned in this Nuremberg Online series of blogs are expected to appear on the market this year and if some of them will not, be assured we will be working hard on them anyway. One of such projects we firmly believe will hit the market sometimes in 2022 is the new 1/48 scale SMB-2 Super Mystere French jet icon. Kindly allow us keep all the other news under wraps, at least for now. The only thing we can tell now is that we do have very secret projects never and nowhere else mentioned before, one in 1/32 and the other in 1/72. So stay tuned...
SH48-SMB2-A.jpg SH48-SMB2-B.jpg SH48-SMB2-C.jpg SH48-SMB2-D.jpg SH48-SMB2-E.jpg SH48-SMB2-F.jpg SH48-SMB2-Z.jpg
 楼主| 发表于 2022-2-11 19:13:55 | 显示全部楼层
Čtvrtý den našeho Norimberku online představujeme další připravované sety CMK. Jde o dvojici setů pro model CL-13 Sabre (Airfix kit), cockpit 4445 a brzdící štíty 4448. Ty se v naší nabídce objeví v březnu. V dubnu je pak bude následovat další dvojice setů pro Sabre, 4446 podvozkové šachty a 4447 otevřené kulometné schránky. Pro dubnové sety na Sabre ještě fotografie nejsou k dispozici. V dubnu také dáme do prodeje první set, N72039 Life Raft pro člun PT-579/588 (Revell kit). Pro ten již fotografie k dispozici jsou.
IMG_8262.JPG IMG_8263.JPG IMG_8264.JPG IMG_8265.JPG IMG_8266.JPG IMG_8267.JPG IMG_8268.JPG IMG_8269.JPG IMG_8270.JPG IMG_8271.JPG IMG_8272.JPG IMG_8273.JPG IMG_8274.JPG IMG_8275.JPG IMG_8276.JPG IMG_8277.JPG IMG_8278.JPG
 楼主| 发表于 2022-2-11 19:15:32 | 显示全部楼层
Normálně v neděli na Norimberku neodpočíváme, ale při Norimberku online jsem si den odpočinku dopřál, respektive jsem se věnoval jiným činnostem. Takže pátý den Norimberku online je až dnes.
   Tématem dnešního dne je model, o kterém se dlouho a hodně mluví. SH72352 Mirage IIICJ 1/72. Začali jsme testovat další dva rámečky, čiré díly a rámeček B. Zatím je ale nemůžeme presentovat. Co ale ukázat můžeme je boxart tohoto modelu. Autorem obrázku je Standa Hájek.
A je to tu. Poslední den. Pohodička na stánku, už v džínách a košili, bez obleku. Jen sledovat oblohu, protože na poslední den skoro vždy přijde sněžení nebo alespoň hustý déšť. Vždyť také jedeme domů.
   Tentokrát jen z kanceláře. V klidu a pohodě, ale bez setkání s lidmi, které známe a máme je rádi. Třeba to příští rok vyjde.
   Na poslední den jsme si nechali větší modely. Tahákem roku 2022 bude určitě model SH48202 AH-1G Cobra 1/48. Ve stejném měřítku připravujeme i L-4 Grasshopper. Zatím je hotový rámeček čirých dílů. Na dalších formách intenzivně pracujeme, ale o tom někdy příště. Poslední chystanou novinkou, kterou se chceme pochlubit je Fiat G.50B Bicomando 1/32.
GMT+8, 2025-3-7 06:16
