查看: 1946|回复: 0
IBG新品(72108)-1/72 英国半人马座 Mk.IV巡航坦克
发表于 2021-12-25 19:04:40 | 显示全部楼层 |阅读模式
IBG新品(72108)-1/72 英国半人马座 Mk.IV坦克建模涂装
IBG Models 1/72 Centaur Mk.IV British Tank - renderings - available soon!
We present the colors and markings of the Centaur tanks that will be included in the upcoming 1/72 scale model. We've slightly modified the approach to creating color options to include the needs of diorama makers. This means:
* The box will contain markings for 6 tanks, as diverse as possible and representing the different steps of the combat trail of this tank. The decals even take into account small differences in markings between vehicles (including angle markings on the turret)
* We included two tanks from each unit. Putting them together on the diorama will be fully aligned with the historical accuracy - there is no doubt that these vehicles fought together
* We reconstructed the appearance of the vehicles of 1st Canadian Centaur Battery, the last unit to use tanks of this type. No photos of them are known, but serial numbers have been identified based on the documents. As these were ex-RMASG tanks handed over in Normandy, we assumed that the earlier unit markings were painted over, and the new ones were not applied, as the 1st Canadian Centaur Battery did not have its own markings. Tanks from this battery can also be safely placed on a diorama with Cromwell tanks from the 6th Airborne Armored Reconnaissance Regiment (IBG set number 72102), because during the capture of the Pont-Audemer 1st Canadian Centaur Battery was subordinated to the 6th AARR
269708212_4747096495411957_3728546989366756007_n.jpg 269692108_4747106108744329_5354792552455651958_n.jpg 269701385_4747106232077650_7014708022119692535_n.jpg 269693035_4747105995411007_2549975412569432583_n.jpg 269717851_4747104808744459_6024987150151729251_n.jpg 269704593_4747106088744331_7403236625945186315_n.jpg 269723799_4747106258744314_5810468929470546085_n.jpg 269715885_4747106198744320_2969881015775207608_n.jpg 269760432_4747104568744483_1664283560517597216_n.jpg 269754943_4747105348744405_8723525849330763414_n.jpg 269760126_4752533131534960_5597241924955331758_n.jpg 269765399_4752533144868292_6478149112564590513_n.jpg 269758518_4752533171534956_5753630126525693451_n.jpg
GMT+8, 2025-3-7 06:38
