查看: 2265|回复: 0
田宫新品预告(35375)-1/35 苏联KV-2重型坦克
发表于 2021-11-23 18:23:22 | 显示全部楼层 |阅读模式
KV-2 1/35 scale, plastic model assembly kit. ★ Overall length 204 mm, overall width 95 mm. Based on the actual vehicle coverage, the powerful figure that surprised the German army is modeled with a high sense of reality. ★ The huge turret realistically expresses the rough texture and welding pattern of the armor surface in detail. ★ Hatch of each part of the car body can be assembled by choosing opening and closing. ★ Tracks are connected to the straight part. The slack at the top is also finished naturally. ★ A full-body image of the commander standing outside the car and a half-body image of the occupant leaning out of the hatch are set. ★ Two types of markings are available.
GMT+8, 2025-3-7 04:39
