查看: 3773|回复: 1
爱德美新品预告(13543)-1/35 德国四号坦克E型
发表于 2021-10-5 17:28:53 | 显示全部楼层 |阅读模式
红星板件Rebox
https://mmzone.co.kr/mms_tool/mt ... z_media&no=6707
The Academy will repack the Zvezda 4 tank type E.
Since then, we have been repacking and releasing Zvezuda products, but this time we will repack our 4th tank E type and SU100.
The only thing that changes in the kit configuration is the decal and the rest of the original kit. These repackaged products are mostly released with the same contents, including box art, as cost savings are a top priority.
Recently, Zvezda products have improved significantly in quality, and this is not a very recent product.  The runner has a feeling of time, but the effort to faithfully recreate the No.4 tank is a kit that can be seen in many places. In some ways, it's better than the recently launched Academy 4.
It reproduces two types of Type 4 tank E and the turret basket. The Turret no.4 appears to have recreated the inside of the turret because it is so visible when it opens a large hatch on both sides.
The track is reproduced in semi-connecting and the composition looks good as if the guide horn is pierced and the upper sagging is reproduced.
I reproduce the carved stamp of the suspension or the carved stamp of the roadwheel faithfully, too.
Tequil has been redesigned by the Academy and dak decals have been added, but the paint manual is missing. It said that it was not able to put the cost rise problem, but it was inevitable due to the tight cost structure of the resurfacing products. I just have to think about this as a service.
It's coming soon and has a consumer value of $38.00.
MMZ20210927164832_2_0.jpg MMZ20210927164833_2_1.jpg MMZ20210927164833_2_2.jpg MMZ20210927164833_2_3.jpg MMZ20210927164833_2_4.jpg MMZ20210927164833_2_5.jpg MMZ20210927164833_2_6.jpg MMZ20210927164834_2_12.jpg MMZ20210927164834_2_7.jpg MMZ20210927164834_2_8.jpg MMZ20210927164834_2_9.jpg MMZ20210927164834_2_10.jpg MMZ20210927164834_2_11.jpg
 楼主| 发表于 2021-10-12 19:20:23 | 显示全部楼层
爱德美新品(13543)-1/35 德国四号坦克E型 东线上市
GMT+8, 2025-3-7 00:43
