查看: 3718|回复: 5
AMMO-MIG新品-2021年5月上市新品
发表于 2021-6-2 19:40:27 | 显示全部楼层 |阅读模式
Acrylic Filter
The Evolution of Weathering
30 references. Jars of 15mL
2,50欧元
AMMO's new acrylic filters are designed to be applied directly to the model. This new range allows you to add colour variation to your miniatures, harmonize various camouflage colours, or distinguish areas with a different tone. The acrylic filter can be easily applied with a brush, which avoids the need for complicated masking. Moisten the brush with the product and apply it without flooding the surface.
Thanks to the innovative formulation, the Acrylic Filters can be retouched or eliminated simply and easily with water during the extended dry time, each filter will dry completely in 24 hours. These versatile filters can also be applied by airbrush for an endless number of effects. Thanks to the wide range of 30 colours available, you won´t need to make complex mixtures, adjust for the proper thinning ratio, or adjust the tone to the intended shade. Each colour can be mixed with one another, or tinted with other AMMO acrylics. The acrylic filters can be diluted and cleaned with water, Acrylic Thinner A.MIG-200 or Cleaner A.MIG-2001
Reference:A.MIG-6146
Title:Stalilngrad Colors. German and Soviet Camouflage in the Battle of Stalingrad
Author/s:Igor Donchik,Daniele Guglielmi
Publisher:AMMO by Mig Jiménez
Subject:Camouflage
Collection:Camouflage profiles guide
Languages:Multilingual: English, Spanish & Russian
No. of pages & Description:Soft cover, 88 pages with high-quality full colour illustrations.
ISBN:978-84-17846-03-9
A.MIG-6146
Stalingrad Vehicles Colors
German and Russian Camouflages
in the Battle of Stalingrad (Multilingual)
18,50欧元
Multilingual book: English, Spanish & Russian
The Battle of Stalingrad certainly was one of the best known and most dramatic of World War II. The historic clash marked a turning point in the conflict. In this book, we will show you the camouflage schemes used on a large number of soft skin and armoured vehicles that took part in this battle to include both German and Soviet examples including the Pz. III, Sd.Kfz. 222, Sd.Kfz. 223, Sd.Kfz. 251, StuG. III, Pz. IV, Marder II, Opel Blitz, Pz.Sfl. IV, T-34, KV-1, KV-1S, GAZ AA, T-26, GAZ-64, and more.
9e559978-7c03-440d-a28b-3d801b4297ef.jpg a6036fdf-f124-4670-94a0-2a4b865c60ee.jpg 2eef612a-65b0-4193-b50b-304b1eb6c7ad.jpg fcfda56a-8f25-45d7-ab25-06bd06a79f61.jpg 619d50cb-1f36-4da3-b96d-d8b80b0eb498.jpg 1a933497-4c99-41bb-a5ee-8a71d642dd69.jpg 3eaeaf9d-b6dc-4140-a856-faad04796c52.jpg 533b878f-f98b-44ae-9c19-d9016bcf81ff.jpg
 楼主| 发表于 2021-6-2 19:49:02 | 显示全部楼层
The Weathering Magazine Issue 33
BURNED OUT
8,00欧元
Reference:A.MIG-4532
Title:The Weathering Magazine Issue 33 - Burned Out
Author/s:Kreangkrai Paojinda, Daniel Morcillo, Lalo Zeleny, Frank Cournede, Mig Jiménez, Ricardo Rivas
Languages:English, Spanish, French, Russian & Polish
No. of pages & Description:Soft cover, 68 pages with high-quality full colour photographs
The latest issue of your favourite magazine concentrates on "Burned Out" subjects: the conflagration and destruction bought about by war on models of all topics. This presents a wide range of interesting painting, weathering and narrative opportunities. Such as the burned out Russian T-72B featured in "Ukrainian Rebel," which explains not only painting and weathering techniques, but also how to modify a tank kit to show damage. In a similar vein "The Würger Is Down" shows how to add damage to a wrecked FW 190D-9, and its immediate surroundings during it's crashed landing. Whilst "Abrams in Ashes" focuses on an M1A1 Abrams during Operation Desert Storm; the result of friendly fire or deliberate damage to prevent capture. Architecture also does not avoid the damage of battle, and Franck Cournede shows the techniques required for modelling a damaged building. Next "The Fallen Soldier" explains step-by-step the different weathering techniques applied to a sci-fi mecha; a great chance to work with extreme weathering in a fictional setting. Then the iconic Jagdpanzer IV/70 (A) is the focus of various weathering techniques while showing the interesting contrast that can be achieved with intact camouflage next to the fire damage of an impact hit. Finally, Mig Jimenez shows how to work with fire damage on 1/700 scale naval models in "Exocet Inferno HMS Sheffield Ablaze," using real photographs to create an accurate and realistic result. No matter the topic of your burned out models, this new issue of The Weathering Magazine is sure to leave you inspired in your projects!
A.MIG-4532
The Weathering Magazine 33 - BURNED OUT
English
0d5843ca-b743-4cda-92a3-3a87407316a7.jpg 0f4b17bb-aa12-42cd-9dbe-9cffb6afcec7.jpg a4d25449-0ea8-430c-9592-7e7a74f5b12a.jpg 85d493c6-6f11-40fc-aa42-2d22ba71831f.jpg 766613d8-797d-4214-b656-bebf70b79165.jpg d6d1ccd3-52de-4a4a-9bec-b6f80fde453d.jpg
 楼主| 发表于 2021-6-2 20:05:19 | 显示全部楼层
The Weathering Aircraft Issue 19
WOOD
9,00欧元
Reference:A.MIG-5219
Title:The Weathering Aircraft Issue 19 -Wood
Author/s:Karim Bibi, Chicho Abad, Manuel Gil, Mario Gabas, Julio Fuentes, Michael Scarborough
Languages:English & Spanish
No. of pages & Description:Soft cover, 60 pages with high-quality full colour photographs
The 19th issue of The Weathering Aircraft is available now! This time we are focusing on the techniques and products necessary to imitate wood surfaces on your aircraft. Quite often, the inherent difficulties associated with these finishes deter modellers from attempting to paint them. Knowledge of the amazing techniques demonstrated will be essential to applying a realistic wood finish to your models. In this issue, a host of exceptional modelers will show you how to simulate wooden surfaces and obtain results that looks exactly like the real thing. Now you can easily learn how to use the correct materials required for each technique, including how to use Oilbrushers, decals, stencils, and we will even show you how to make your own tools.
A.MIG-5219
The Weathering Aircraft 19 - Wood
English
2675acd9-cb89-4a77-82c6-8ff68166457a.jpg 8e4cbda0-8e5c-46dc-8ccd-ef4db61edb09.jpg 48eaea8a-fdcd-4364-ac19-755e48f1da25.jpg 80f25e3f-5835-49ce-863a-edcbef2b9c40.jpg 812a20cd-bd40-4be4-b679-aaa4875925d6.jpg 913df77f-4d82-4900-afed-7cf984d15f97.jpg d8350759-b5ae-4302-856f-5648d177fd0b.jpg 12ec9fc1-dbaf-4d8d-9d1c-35b3ff13245b.jpg
 楼主| 发表于 2021-6-2 20:28:44 | 显示全部楼层
A.MIG-7039
WWII US Paratrooper Uniforms
Acrylic colours set for figures. 6 jars 17mL
13,80欧元
This pack includes all 6 colours required to paint the standard uniform of American paratroopers during World War II. This includes the famous 82nd and 101st Airborne Divisions from Operation Overlord (D-Day) to the end of the conflict. The colours have been selected through rigorous research of period equipment, allowing you to accurately paint the base tones of uniforms, add highlights, and enhance details.
Included colors in this Set:
AMMO.F-504 Yellow Green
AMMO.F-560 Khaki Grey
AMMO.F-561 Green Violet
AMMO.F-562 Light Ochre
AMMO.F-563 Buff
AMMO.F-564 Military Green
A.MIG-7180
REGIO ESERCITO WWII
Acrylic Smart Set - 4 jars 17mL
A collection of the specific colours most commonly used by the Regio Esercito during World War II. In addition to tanks, these colours were also used to camouflage trucks, motorcycles, tractors, and artillery.
9,20欧元
A.MIG-0238 FS-34092 Medium Green
A.MIG-0275 Giallo Mimetico 3 FS-33434
A.MIG-0277 FS-34159 Green Grey
A.MIG-0912 Red Brown Shadow
A.MIG-8129
1/35
Panzer I Tools
Printed in resin with the latest 3D technology.
Tools for the Panzer I German tank. Can be used on any Panzer I in 1/35th scale.
Suitable for models from all manufacturers.
6,50欧元
A.MIG-8130
1/35
Panzer II Tools
Tools for the WWII Panzer II German tank. Can be used on any Panzer II in 1/35th scale
6,50欧元
A.MIG-8142
1/35
Heavy Panzer Hooks
Towing hooks for WWII German heavy Panzers. Can be used on all German heavy tanks in 1/35th scale
7,75欧元
A.MIG-8143
1/35
Medium Panzer Hooks
Towing hooks for WWII German medium Panzers. Can be used on all German medium tanks in 1/35th scale
5,25欧元
A.MIG-8144
1/35
Dented Jerrycans
Can be used on all types of German vehicles and scenes in 1/35th scale, as well as captured by Allied troops.
11,50欧元
 楼主| 发表于 2021-6-3 18:48:40 | 显示全部楼层
A.MIG-8555
Sanding sponge sheet 100
This 100-grit sanding sponge is perfect for surfaces with large imperfections or hard and resistant materials. The flexibility of the material easily conforms to any shape including rounded surfaces and hard-to-reach recesses. This product can be used on a full range of materials including resin, metal, wood, and of course plastic. It’s also highly useful for removing traces of glue or putty when filling gaps. It can be used both dry and moistened with water.
3,95欧元
A.MIG-8556
Sanding sponge sheet 180
This 180-grit sanding sponge is perfect for surfaces with imperfections or to refine the work done with the 100-grit. The flexibility of the material easily conforms to any shape including rounded surfaces or hard-to-reach recesses. It’s also highly useful for removing traces of glue or putty when filling gaps. It can be used both dry and moistened with water.
3,95欧元
A.MIG-8557
Sanding sponge sheet 220
This 220-grit sanding sponge is perfect for surfaces with small defects or to refine the work done with the 180-grit, especially when smoothing out gaps sealed with glue and/or putty. It can also be very useful as a first step in removing small blemishes or imperfections from clear parts. The flexibility of the material easily conforms to any shape including rounded surfaces or hard-to-reach recesses. Can be used on a full range of materials including resin, metal, wood and, of course plastic. It’s also highly useful for removing traces of glue or putty when filling gaps. It can be used both dry and moistened with water.
3,95欧元
A.MIG-8558
Sanding sponge sheet 280
This 280-git sanding sponge is perfect for finishing areas previously refined with coarse grits. Ideal for the final touch-up to clear parts before polishing them. The flexibility of the material easily conforms to any shape including rounded surfaces or hard-to-reach recesses. . Can be used on a full range of materials including resin, metal, wood and, of course plastic. It’s also highly useful for removing traces of glue or putty when filling gaps. It can be used both dry and moistened with water.
3,95欧元
A.MIG-8566
POLISHING SANDING STIKS
This sanding stick provides 2 different grits: 400/4000, ideal for eliminating defects and also for creating a very smooth finish. The 400 grit can be used to remove mould seams, scratches, traces of glue, putty, and other defects. With the 4000, you will be able to polish the surface. This side is especially useful for polishing clear plastic parts, removing the glossy finish from decals, or polishing previously painted surfaces. The flexibility of the material easily conforms to any shape including rounded surfaces. Can be used on a full range of materials including resin, metal, wood and, of course plastic. It can be used both dry and moistened with water.
1,95欧元
A.MIG-8567
TAPERED SANDING STIK
Assortment of 6 sanding sticks of varying grits: 120/180/240/320/1200/1500. Designed for use on both small and large surfaces thanks to their unique feature: while one is wider and can be used on larger areas, the narrow portion can be used for hard-to-reach areas and small parts. The more aggressive grits are particularly useful for gradually eliminating the most prominent surface defects, while the two finest grits can be used to create an extremely fine and smooth finish, leaving the surface ready for painting. Can be used on a full range of materials including resin, metal, wood and, of course plastic. This abrasive can be used both dry and moistened with water.
4,50欧元
A.MIG-8568
CONTOUR SANDING STIK
Assortment of 6 sanding sticks with different grits: 120/180/240/320/1200/1500. Designed for precise sanding jobs on small, delicate or hard-to-reach parts at just 4 mm, just a bit over 1/8” wide. We recommend using the coarse grits to gradually eliminate the most prominent defects, while the two finest grits should be used to obtain an extremely fine and smooth finish, leaving the surface ready for painting. Can be used on a full range of materials including resin, metal, wood and, of course plastic. It can be used both dry and moistened with water.
1,75欧元
A.MIG-8049
AIRBRUSH STENCILS
These photo-etched stencils will allow you to accurately depict worn and discoloured surfaces and represent repainted areas by simply placing the sheet over the desired surface and then airbrushing colour at a low air pressure. You can also achieve soft-edge patches by slightly separating the stencil from the surface of the model to paint mottled camouflage patterns. One of the three three sizes included in this set mimics cracks and can be used on the walls or floors of your dioramas. After each use, always clean the paint from the stencil carefully with Cleaner A.MIG-2001.
14,50欧元
 楼主| 发表于 2021-6-3 19:01:46 | 显示全部楼层
A.MIG-8622
10 SYNTETIC FLAT BRUSH
The Synthetic Brush range made of high-quality fibers, offers great spring and color carrying capacity, making them an excellent option to paint medium and large areas of our models. The ideal brush for working with military vehicles, aircraft, groundwork, and all manner of scale models. Thanks to the fine point, smaller sizes are also suitable for detail painting.
2,75欧元
A.MIG-8057
AMMO TACTICAL BADGE
Size: 58 x 75 mm
4,00欧元
Military AMMO official logo patch with PVC finish and velcro fastening.
1e588aa0-7bc6-4b9e-c08e-75b40067db66.jpeg 90abd36f-615b-f917-5693-4207eb650946.jpeg
DH-017
Sukhoi Su-25 Frogfoot
DH-017 brings a complete photographic portrait of the Sukhoi Su-25 Frogfoot, the Russian jet specifically designed for close support missions. In this 116 page book, every detail of the aircraft is shown in detail, from fuselage to landing gear, wings, and of course the cockpit. This book includes photos of the original Su-25, up to the most modern versions such as the Su-25 Mimino and Su-25 SM3-9.
23,00欧元
Reference: DH-017
Title: Sukhoi Su-25 Frogfoot
Publisher: HMH Publications
Languages: English
No. of pages Book, Soft cover, 116 pages (240 mm x 240 mm)
ISBN 978-2-931083-07-9
8c4c2571-9ccb-47fb-ae20-b1ec965d0bcf.jpg f823a234-6768-4f23-8676-f641a36d437f.jpg 8e8b8a4d-f2e3-4270-89bb-59b65d2f5e3a.jpg
DH-018
Dassault / Dornier Alpha Jet
DH-018 is a 116-page book showing the Dassault/Dornier Alpha Jet. Included are the A-version, the E-version as well as the updated Alpha Jets - this is the first time such a detailed portrait has been made. Aircraft from many air forces are included, such as France, Belgium, Germany, Portugal, Morocco, Thailand and Nigeria. An 18-page maintenance chapter is included in this newest book by HMH Publications.
23,00欧元
Reference: DH-018
Title: Dassault / Dornier Alpha Jet
Languages: English
ISBN 978-2-931083-08-6
b8eab231-4f62-4448-83de-dc1990c57b0e.jpg 6da07a01-2584-4a9e-bb4b-1445889aec4b.jpg b1b54395-81f6-4c27-81d8-c3113ffafc01.jpg
GMT+8, 2025-3-6 11:40
