查看: 2647|回复: 0
Answer新品预告-1/48与1/72 PZL-104 Wilga 35A和80
发表于 2021-5-27 19:57:36 | 显示全部楼层 |阅读模式
Answer新品预告-1/72 PZL-104 Wilga 35A封绘
Answer Plastic Kits is to release 1/48th & 1/72nd Państwowe Zakłady Lotnicze PZL-104 Wilga 35A & 80 kits.
Good evening
Since spring doesn't want to come and the reality around us has become a bit surreal (some say it's even final times), we've come to the conclusion that there's nothing to delay, you have to act, taking advantage of the temporary break that the pandemic has taken. So we decided to launch the 'Wilga' project and implement a model, or rather models, which during the raging covid surface winter we worked on in the privacy of our secret underground lab. In sweat, like Wuhan biochemists and genetics, our designers fought 3 d matter day and night. Currently, the work on Wilgas is advanced enough to announce this information officially. The plural has been used here for a reason, because the Wilgas will be in two scales-1/72 and 1/48. I don't think the plane needs to be more broadly presented - Wilga as it is, everyone knows. For starters, two versions - Wilga 35 A and Wilga 80. We don't know exactly how many editions there will be yet, because there are no liquefied paintings. If all goes well then set 1/72 will be right after the first Bies. And Biesy is just around the corner.
More details soon.
GMT+8, 2025-3-6 11:34
