查看: 4030|回复: 3
田宫新品-2021年2月上市新品
发表于 2021-1-17 20:11:13 | 显示全部楼层 |阅读模式
32599 1/48 俄罗斯中型坦克 T-34-85
This plastic model assembly kit recreates the hardy and dependable T-34-85 tank notably deployed by Soviet forces as they advanced on Germany in late WWII. Features a realistic depiction of the powerful form with bulky turret and long-barreled 85mm gun. Recreations of cast metal texture and weld lines add an extra layer of detail. Tracks are assembly type, with single-piece straight sections. Comes with a commander torso figure and two marking options.​
Realistically reproduce the solid and robust style that gathered a lot of trust from Soviet soldiers. The turret with plenty of weight and the long barrel 85mm gun that raged in the offensive of the second half of the war attract the eye.
A turret that sticks to the rough casting texture unique to Soviet tanks and the expression of welded patterns. I put my hand on a one-piece cupola hatch and set a half-body image of the car length looking forward.
The wide track adopts a connecting type that combines the straight part, achieving both a sharp finish and ease of assembly. The three-dimensional modeling of the rolling wheel is also noteworthy.
Increased fuel tank that emphasizes the martial atmosphere, spare track etc. are also part without leaving. The delicate details of the engine grille add to the sense of scale.
24355 1/24 迈凯伦 塞纳
1/24比例,长198mm,宽91mm,高51mm;忠实还原了实车复杂的空气动力学外形;为了方便上色,将车门部件和玻璃、座椅和坐垫合理分件,刹车盘和刹车卡钳也是单独开模;V8双涡轮发动机细节丰富外形震撼,同时控制零件数量,方便组合;还原了前后散热器部件;足以乱真的内饰细节;开关车门的气压撑杆单独开模;仪表盘可制作成展开或缩回状态;迈凯伦标志为金属材质;纹理精细的实心橡胶轮胎;前轮可转向;可选择制作成美规、欧规或日规。
还原了实车复杂的空气动力学外形
 楼主| 发表于 2021-1-17 20:15:49 | 显示全部楼层
还原了车身中段的V8发动机,副车架和悬挂的细节也非常丰富
车顶和车窗的透明件无需使用胶水固定即可安装,也无需单独上色
透明件通过巧妙设计的定位槽即可轻松安装到位,后期安装的覆盖件会遮挡住定位槽,无需胶水固定
车门上的透明件也无需胶水即可固定安装
刹车盘和卡钳独立开模,方便上色
排气管有美规(左)和欧规(右)两种样式可选
仪表面板选择全显示模式(部署状态:右)和超薄显示模式(存储状态:左)
座椅和坐垫分开开模,方便搭配出不同颜色的座椅
还原了大灯下方进气口处的叶片
还原了实车的天鹅颈造型的大型尾翼支架,支架底部的波浪形基座也一并还原
 楼主| 发表于 2021-1-17 20:34:06 | 显示全部楼层
平整的车底细节,双层的尾部挡板气势十足
14029 1/12 铃木 RG250Γ(伽马)含所有选装件
With its racing bike looks, the RG250 Γ (Gamma) was an instant hit with the public upon its March 1983. This model recreates the motorcycle in detailed 1/12 scale, from the 45hp 2-stroke 2-cylinder engine to the racing frame and Suzuki's unique Full Floater rear setup. Undercowl and single seat cowls are separate parts. Modelers can choose to assemble the kit as a half-cowl/tandem seat or full-cowl/single seat model. Vinyl tubing recreates the various cables and lines, for a realistic finish. Gamma stand is included.
Length: 167mm, width: 57mm, height: 99mm.
This model originally went on sale in Japan in December 1983.
14024 1/12 铃木 RG250Γ(伽马)
Advanced Ride
The RG250 Γ benefitted greatly from Suzuki's race-developed technology. It utilized an aluminum double cradle frame with a 247cc 2-cylinder engine that provided 45hp, as well as dedicated tires and a distinctive half cowl.
About the Model
This is a 1/12 scale plastic model assembly kit. Length: 167mm, width: 57mm, height: 99mm.
Features a realistic depiction of the 45hp liquid cooled 2-cylinder engine, with carburetor and pipes accurately captured.
Solid synthetic rubber tires feature accurate tread patterns.
Vinyl tubing is included for the recreation of various pipes and lines on the motorcycle.
Accurate renderings of refined cowl shapes.
20069 1/20 菲亚特 131 阿巴斯拉力赛OLIO FIAT
[Three-time champion, rally-history masterpiece FR machine] Fiat 131 Abarth Rally is a masterpiece FR (front engine / rear driven) machine that debuted at the World Rally Championship in 1976 and won three champion cars in 1977, 1978 and 1980. The base is 131 Mirafioli, fiat's representative family car at the time. A thorough remodeling has been made to the details to fight the rally. He was in charge of Abarth, a famous Italian tuner. The in-line 4-cylinder DOHC4 valve engine with a displacement of 1995 cc generates a maximum output of 215 horsepower, and the suspension is remodeled into a four-wheel independent suspension of Macpherson Strut, equipped with a powerful benched disc brake both before and after. In addition, the body equipped with a front and rear spoiler and over fender has been replaced with FRP in many parts to reduce weight. Works cars from 1976 and 1977 were mainly painted in dark blue and yellow, which is also the image color of Fiat's genuine oil OLIO FIAT, and fought the season.
This 1/20 scale plastic model assembly kit recreates the 1977 version of the three-time Fiat 131 Abarth Rally.
The classic form of the car is recreated in style, from the front and rear spoilers to the bulging overfenders.
Features a detailed depiction of the Abarth-tuned inline-4 DOHC engine.
Includes decals for markings, and masking stickers for the paint job.
In a boxy 2-door sedan, reproduce plenty of fearless form equipped with an over fender and a front and rear spoiler.
The bonnet that opens with the front hinge is retractable. The in-line 4-cylinder DOHC engine also reproduces the ignition cord, and auxiliary equipment such as radiators, oil coolers, and triangular reinforcement bars are also finished.
Trunk lids can also be opened and closed by hinges. Inside, fuel tanks and batteries with shapes that avoid spare tires and tires are also modeled.
 楼主| 发表于 2021-1-17 20:40:07 | 显示全部楼层
As well as large slide marks for marking, mask seals for painting are also set.
69938 模型笔刀(红色)
[Knife that performs delicate work] Red grip that stands out well on the work desk produces the fun of modeling. Ideal for finishing parting lines of fine parts and molding after the putty of doll remodeling. The delicately finished cutting edge is tenacious and durable, and is also active in shaving plastic. It is characterized by the difficulty of spilling the blade even when the blade is stood up and shaved.
[Basic specifications] 25 spare blades, case to put used blade, with cap.
GMT+8, 2025-3-5 06:20
