查看: 5584|回复: 5
Brengun新品预告-1/72 亨舍尔 Hs.126
发表于 2021-1-12 15:10:08 | 显示全部楼层 |阅读模式
Brengun新品预告-1/72 亨舍尔 Hs.126建模试模
Brengun is to release a 1/72nd Henschel Hs.126 kit - ref.
134391046_1744751742350133_5777033558565925299_o.jpg 134646898_1744751739016800_7007873639778744902_o.jpg 134812750_1744751815683459_5575422211796141401_o.jpg 134457887_1744751722350135_1688874829850329337_n.jpg 134567555_1744751845683456_2734347517936582089_o.jpg 134348052_1744751882350119_5574551491639781543_n.jpg 136324187_1749844288507545_2556593645195459005_n.jpg 136664852_1749844315174209_8285001626669431363_n.jpg 136318740_1749844338507540_4495527932838654036_n.jpg 136350100_1749844365174204_6177686513602272316_n.jpg 137220863_1753398204818820_6869397976428165354_n.jpg 137606976_1753398258152148_3909960240123250548_n.jpg 138132914_1753398311485476_7417557506964667795_n.jpg
 楼主| 发表于 2021-1-14 18:37:10 | 显示全部楼层
Brengun新品预告-1/72 亨舍尔 Hs.126更新
 楼主| 发表于 2021-1-19 19:16:21 | 显示全部楼层
Brengun新品预告-1/72 亨舍尔 Hs.126试模作品
139462754_1757454687746505_9083675443428961593_n.jpg 139649919_1757454721079835_4100117226989030378_n.jpg 139649314_1757455161079791_7774230022005317380_n.jpg 140025815_1757455194413121_3511147581048089116_n.jpg
 楼主| 发表于 2021-1-29 18:58:09 | 显示全部楼层
Brengun新品预告-1/72 亨舍尔 Hs.126 A-1/B-1封绘
- ref. BRP72044 - Henschel He-126A-1
- ref. BRP72045 - Henschel He-126B-1
 楼主| 发表于 2021-2-24 16:28:37 | 显示全部楼层
Brengun新品-1/72 亨舍尔 Hs.126 A-1/B-1与改件上市
- ref. BRP72044 - Henschel Hs.126A-1 „Superpava“ Legion Condor
Source: http://www.brengun.cz/e-shop/1-72-plastic-kits-28/hs-126-a-1-„superpava“-legion-condor-1810
- ref. BRP72045- Henschel He-126B-1
Source: http://www.brengun.cz/e-shop/1-72-plastic-kits-28/hs-126-b-1-1811
- ref. BRL72247 - Photoetched and resin set for Brengun kit
Source: http://www.brengun.cz/e-shop/1-72-accessories-21/henschel-hs-126-(brengun-kit)-1812
 楼主| 发表于 2021-4-17 17:59:13 | 显示全部楼层
I just received the new Brengun Henschel 126 and compared it with the Airfix model (the best of the existing kits until now). I compared both kits with Kageros plans and the comparison was disappointing.
Although the Brengun kit has a very good detail the dimensions of the wing and fuselage are shorter.
Has anybody compared the Sabrekits Henschel 126?
Best regards,
Octávio
51117724254_2971e55e55_z.jpg 51117971736_9a8e46ebae_z.jpg 51117971776_c6bd84344c_z.jpg 51118768780_1f4cd6cd15_z.jpg
GMT+8, 2025-3-6 02:02
