查看: 2446|回复: 5
AMMO-MIG新品-2020年8月上市新品
发表于 2020-8-26 19:11:32 | 显示全部楼层 |阅读模式
Dear friend.
Today we want to share with you the latest addition to AMMO Publications, two new magazines ( The Weathering Magazine 31 - Beach & The Weathering Aircraft 17 - Decals & Masks), two new Solution Books, new sets, auxiliary products, and much more..
A.MIG-6521
SOLUTION BOX
BARE METAL AIRCRAFT
Colors and Weathering System
76 ,95欧元
SOLUTION BOX BARE METAL AIRCRAFT will guide you through the complete painting and weathering process for bare metal aircraft subjects from any era.
    Many aircraft throughout the history of aviation have been flown entirely or partially in their bare metal skins. These iconic aircraft include the P-51 Mustang, P-38 Lightning, B-29, Ju-52, F-86 Sabre, F-104 Starfighter, BAC Lightning, and most post-war Soviet aircraft, such as the MiG-15, MiG-17, MiG-19, MiG-21 and the famous Tu-95 “Bear” and Tu-142 bombers. These are just a few well known examples; the list of combat and civilian aircraft featuring bare metal surfaces is almost endless. Simply grab your favourite model and start painting without further delay!
SOLUTION BOX is a simple and comprehensive system providing you with everything required to paint and weather your models. This includes the application of primer and the camouflage colours, as well as the full range of painting and weathering effects for this subject. The correct products and colours are included for applying washes, fading and highlights with oils, streaking, chipped paint, dust, dirt and mud, and even oil and fuel stains.
    This box includes everything except the model kit!!! A great idea and solution for every beginning modeller and those experienced modellers that enjoy the accuracy and convenience provided by the Solution Box.
Included products in this Solution Box:
A.MIG-0187 Jet Exhaust Burnt Iron                             A.MIG-2023 One Shot Primer Black
A.MIG-0191 Steel                                                     A.MIG-2055 Matt Lucky Varnish
A.MIG-0192 Polished Metal                                        A.MIG-3009 Gun Metal
A.MIG-0194 Matt Aluminium                                                            A.MIG-3021 Polished Metal
A.MIG-0195 Silver                                                    A.MIG-3535 Oilbrusher Gun Metal
A.MIG-1253 Streaking Brusher Grime                         A.MIG-3538 Oilbrusher Silver
A.MIG-1256 Streakingbrusher Green-Grey Grime         A.MIG-8212 Aqua Gloss Clear
A.MIG-1617 PLW Blue Black                                       A.MIG-8215 Airframe Aluminium ALC119
A.MIG-1618PLW Deep Brown                                     A.MIG-8595 4 Synthetic Filbert Brush
A.MIG-2016 Transparator 17mL                                                       A.MIG-8612 2/0 Synthetic Round Brush
A.MIG-2018 Enamel Odourless Thinner                       A.MIG-8613 #1 Synthetoic Round Brush
In addition, this comprehensive set includes the easy to use
BARE METAL AIRCRAFT. COLORS AND WEATHERING SYSTEM Solution Book (Multilingual)
A.MIG-6521
SOLUTION BOOK
How to Paint
9,95欧元
Book, soft cover, 60 pages in full colour. Multilingual
English, Spanish, French & German.
HOW TO PAINT BARE METAL AIRCRAFT SOLUTION BOOK is a complete guide that explains step-by-step how to paint and apply a range of realistic weathering effects to any aircraft of any age with a bare metal fuselage, including such iconic aircrafts as P-51 Mustang, P-38 Lightning, B-29, Ju-52, F-86 Sabre, F-104 Starfighter, BAC Lightning, and most of the post-war Soviet aircraft, such as the MiG-15, MiG-17, MiG-19, MiG-21, the famous Tu-95 “Bear” and Tu-142 bombers…and many more.
SOLUTION BOOK is a simple and easy to follow guide which allows any modeller to obtain effects and finishes similar to the examples shown. It doesn't matter if you are a beginner that has just recently started to paint your kits, or a more advanced and experienced modeller. With this guide you can achieve amazing effects with very little effort by following a few simple steps.
5afe4f95-52ff-4da7-8d59-809671db7f85.jpg 1e321e47-51cb-4415-a956-baabe39b64eb.jpg d12ee25e-1321-442b-bbe6-c5aafc321bfa.jpg fe3f03b9-767c-4a97-83bc-12220815c99f.jpg 7e22c834-63cc-47d2-a957-1f87a31fe6d3.jpg 2506c66b-afe1-4c08-95e0-d1ad2ba0d24d.jpg
 楼主| 发表于 2020-8-26 19:30:17 | 显示全部楼层
A.MIG-6509
SOLUTION BOOK
How to Paint
USAF NAVY GREY FIGHTERS
9,95欧元
  SOLUTION BOOK is a simple and basic guide intended to help any modeller easily achieve similar results to those shown in each example. It doesn´t matter if the reader is a novice or a more seasoned and experienced modeller, by following the steps in this guide they will be able to obtain amazing results with the efficient and effective methods shown. SOLUTION BOOK´s new design will allow you to follow each step in a very easy and intuitive manner without text by using a simple icon-based code that will show what to do at each step. By following the steps shown in this guide, you will be able to achieve excellent results with very little effort.
53440473-3897-49e3-80a2-3e4df2c4fcc3.jpg cc563a3c-56c7-444d-90ab-88eb384e72e2.jpg 97b292f8-82b4-4956-b4d4-dcaee2e7de27.jpg a041d0cd-7a25-4ca2-b986-6733d1979139.jpg 6f9333f3-3007-4d35-b677-c5771fc82efd.jpg e947a534-8bff-48c0-8f1e-5a9a2d34cc72.jpg 01edd251-e512-4474-aeb9-05441db9e507.jpg 46b1d5ec-c398-4e6a-9a1b-58f2f743dc93.jpg
4fa28b9e-5e14-4182-963f-3893d6068a04.jpg 229481db-5739-4186-922a-de6160d937c4.jpg
A.MIG-7032
COMPLEMENTARY COLORS. FIGURE SET
Acrylic colours set for figures. 6 jars 17mL
13,80欧元
In this set you will find the 6 complementary colours essential to mixing almost any shade. These colours can be used individually or mixed with any other AMMO acrylic colour. These tones are highly saturated and have excellent covering power.
AMMO.F-538 Bright Orange                AMMO.F-541 Rust Ochre
AMMO.F-539 Bright Violet                  AMMO.F-542 Phthalo Green
AMMO.F-540 Magenta                       AMMO.F-543 Green Blue
A.MIG-7804
WEATHERING ENGINES SUPER PACK
33,95欧元
This set contains the essential base colours and weathering products required for painting surfaces and reproduce effects of gunk and grime on any engine. With these colours and effects, you will be able to simulate different types of metals, spilled fuel, oil, dirt, and mechanical fluids. This set is the perfect solution for every beginner and effective and useful for those more experienced modellers that enjoy the accuracy and convenience provided by this all-in-one option.
Included products in this Super Pack:
A.MIG-0045 Gun Metal                                        A.MIG-1408 Fresh Engine Oil
A.MIG-0187 Jewt Exhaust Burnt Iron                     A.MIG-1409 Fuel Stains
A.MIG-0191 Steel                                               A.MIG-3001 Black
A.MIG-1008 Dark Wash                                       A.MIG-3020 Metal Slag
A.MIG-1253 Grime                                              A.MIG-3510 Rust
A.MIG-1407 Engine Grime
 楼主| 发表于 2020-8-26 19:43:18 | 显示全部楼层
A.MIG-8042
Flexible Masking Tape
(3mm x 33m)
5,95欧元
Flexible high-quality masking tape for precision work, making it ideal for airbrushing and designed with a firm sealing edge. This flexibility allows you to apply curves and rounded shapes, obtaining a uniform result when painting free of unrealistic sharp angles or defects. This also allows the tape to adapt and conform to complex surfaces. This tape features a residue free adhesive, ideal for scale models and fine or delicate finishes. The strength of this tape allows it to be used as a guide to engrave or scribe details in plastic. This tape can be easily be cut to shape with scissors or hobby knife.
A.MIG-8044
Double-Sided Soft Tape
(15mm * 10m)
3,75欧元
This high quality double-sided adhesive tape is intended for precision work and designed specifically for modelling use. Ideal for holding parts during the painting process, allowing you to avoid handling or damaging the surface with tools. Each side has a different residue free adhesive strength: the white inner surface has a stronger adhesive for a more durable bond, while the green surface is a lower tack for fine tasks. This allows the part to be firmly attached to the desired surface while also allowing you to delicately handle fragile parts and fine finished surfaces without fear of damaging your work. This tape can be easily be cut to shape with scissors or hobby knife.
A.MIG-8046
INSTANT DRY CYANOACRYLATE
7,95欧元
Cyanoacrylate type glue suitable for bonding a large number of materials including plastic, metal, wood and resin among others. Provides an extremely strong bond in only 10-15 seconds. Always clean the surfaces to be joined before application. TRUE Cyanoacrylate can be applied directly from its nozzle or by using a fine tool for greater precision. The resulting joint will resist temperatures up to 150 degrees Celsius, and forces up to 180 kg / cm2. The adhesive flows easily by capillary action and is resistant to water, stress, and vibration.
It also withstands water, shock and vibration perfectly. It can be used directly from its nozzle or applied with a pointed tool for greater precision acting easily by capillarity
A.MIG-8047
MAGIC DUST
6,95欧元
With this powder you can strengthen and reinforce cyanoacrylate joints. It can also be used as a putty to fill gaps. This versatile product is easy to use and features a dispenser for precise application. Simply apply the product over the cyanoacrylate to speed up the cure time. The application process can be reversed: apply Magicdust 21 first and then the CA glue, leave the product to cure for approximately 5 minutes. Any excess can then be sanded away, the solid surface can also be engraved. If necessary, the application process can be repeated until the desired result is obtained.
A.MIG-4530 BEACH
Magazine, Soft cover, 72 pages in full color
8,00欧元
The latest issue of your favourite magazine concentrates on an iconic scenic feature: the beach. A great environment for our model kits and dioramas, whilst presenting interesting weathering and narrative opportunities across multiple themes. For example, as the setting for a sci fi battle: “Battle on the Beach” shows the result of a conflict between two amphibious mecha: MSM-07 Gok Production & MSM-04 Acguy. Whilst “Surfin Bird” shows a much more peaceful scene with a landed Douglas TBD-1A and the effects of sea and sand weathering on aircraft, as well as the transition between sand and vegetation. A less tranquil beach is shown in the “Boat that Won the War,” which shows how to create violent waves, and the LCVP caught in them. An AAVP7A1 RAM/RS amphibious assault vehicle is then shown step-by-step, detailing the weathering of sand on the tracks of an armoured vehicle, as well as the wet effects caused by it's journey. “What Lies Beneath” shows the German coastal defences of France in 1944, and how to paint and weather the camouflage of the defences, and model its surroundings overlooking the beaches. “The Lonely Bay” takes a more panoramic view in showing how to create the illusion of depth within the sea, and waves crashing on the coast. Finally, “Wading Sherman” shows a partly submerged Sherman in 1/72 scale. A gallery of author's beach scenes will help to inspire more beach themed models and dioramas: whether a beginner or experienced model this issue will leave you inspired!
349563e1-a68b-40ae-a4c0-64fd35559c25.jpg db7f62f5-d0a4-4d39-aba3-216386e580f8.jpg a04df9e9-08f5-4a0e-9d72-b42766ec2304.jpg 24bf9b04-e0ae-4ace-84c2-7d66a161bf03.jpg 38e0d6f5-2c2c-4838-af98-3a7e74ba9d26.jpg cfbd02ee-b0d0-488d-a411-4a44889980ec.jpg 883689af-c1c7-47cc-94c8-fe4d06c25d87.jpg 9dc4fc8d-b0ae-4fd7-872a-1ad8d1bfff02.jpg
 楼主| 发表于 2020-8-26 19:57:57 | 显示全部楼层
A.MIG-5217 DECALS & MASKS
9,00欧元
We often find decals that are either difficult to use, out of scale, or the required are not available for the intended subject. In this issue, you will learn how to overcome these all too common issues and how to create masks used for painting authentic markings instead of using decals. Mastery of specific techniques is essential to apply realistic markings, numerals, and stencils that are perfectly integrated into the finish of any subject. Some of the worlds most talented modellers have contributed to show you all aspects of masks and decals and the different ways to both make and use them. You will learn how to tackle difficult decals and how to solve common problems including the dreaded silvering effect, glossy surfaces, and water-slide markings that do not conform to raised and recessed details. This issue of TWA will also show you some tricks and tips including specific products and varnishes that must be used before and after applying markings to avoid unpleasant surprises and ruined finishes.
e09c2242-acfe-4f69-9498-49bd1d125229.jpg 8e8dcc82-260c-418c-9bc6-62a048edb3c8.jpg 577e4e69-6fd7-4bda-b1f2-57ef3a3f738b.jpg 6b137916-d2f2-4831-992c-93918c28a6f5.jpg 1c2fdf53-53f2-4ce6-a38c-4532b4b04696.jpg 9b0ee910-f006-45d2-809e-1547cf76a473.jpg 27a7e699-c318-4f7a-ac33-88f3ab565ed4.jpg
EURO-0029
Diorama Project 1.2 - WW2 Figures (English)
Book, Soft cover, 152 pages in full color.
25,00欧元
Diorama Project was born with the idea of learning how to make all the elements of a diorama, vehicles, figures and set design in a simple way. This volume is focused on how to paint figures.
678d3925-3b40-4d1d-b651-0e7e08dd44c0.jpg 28f13a07-985c-4f58-bacf-acc491c729be.jpg 0f4016b8-fbde-46b5-a627-a48cc69c5b45.jpg dc52cc64-50bf-41c4-a9ee-a1b044762a0e.jpg
 楼主| 发表于 2020-8-26 20:05:11 | 显示全部楼层
DH-S001
Juan Carlos I, Spanish Aircraft carrier (English)
Photographers:
Kris Christiaens & Gert Trachez
Soft cover, 108 pages
23,50欧元
1f328f7c-da33-46fb-b136-90f6ade94d77.jpg 28bb925d-0b97-43c3-ae17-19d8e9a3a2ce.jpg b38d9a7b-c68c-407f-9146-d9bb7be8a54a.jpg
发表于 2020-8-26 23:45:51 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-3-4 17:27
