查看: 2405|回复: 0
Das Werk新品预告(DW35001)-1/35 Faun L900硬顶
发表于 2020-8-21 18:54:38 | 显示全部楼层 |阅读模式
        9吨坦克运输卡车(含软顶驾驶室)
Highly detailed static plastic model
Hartop Version with accurate representation
3 different suspension springs for different load status
(Unloaded, Neutral and Full loaded)
Freightbed side walls buildable up or downwards
Contains brass tubing with bendig jig for freight bed arches
Our first major project in 2019 was the Faun L900 incl. Sd.Ah.115.
The new kit is based on the original model kit in many respects.
After the release, we received a lot of feedback from you. The vast majority was very positive, but there were also some criticisms respectively parts of the kit that we could have done better.
We have taken this feedback to heart and discarded our original plans to launch the Faun L900 individually again as a Softtop version.
In these points, the new hardtop version differs from the truck of the combi kit:
Hardtop Cabin
(The parts for the soft top version are additionally still included.)
Improved towing hitch/hook
Improved exhaust system (muffler)
New multiple part plastic wheels with corrected dimensions
image.jpg 3500101.jpg 3500102.jpg 3500103.jpg 3500104.jpg 3500105.jpg 3500106.jpg
GMT+8, 2025-3-4 18:22
