查看: 4131|回复: 2
爱德美新品预告(13531)-1/35 三号坦克J型 1942年北非
发表于 2020-7-24 19:53:20 | 显示全部楼层 |阅读模式
The Academy announced the development of the 1/35 scale German Type 3 Tank J-type and will launch in Korea in September 2020.
We'll get the final shot of this product and let's take a look at it. The product introduced earlier in the text is the final prototype, not the mass production, so there may be some other parts of the product.
Since introducing The New Mold King Tiger in 2013, the Academy has introduced four new cars and panters as new molds, creating a new lineup of German vehicles. As part of this move, we've developed the 3rd Tank and released the J-type African Legion type as the first series.
It consists of a total of seven runners. It's a bit more than the size of a tank. Let's look at each runner.
The runner consists of the lower body, the side, the front and rear, and the muffler parts, which are the trend of the kits these days, without making the body part in one piece.
The body composition is not very characteristic and is generally considered a common configuration.
The runner consists of a body superstructure, front, side gloves, side fender, front fender, engine grille and ovm components.
Overall, the mold is sharp and clean, which may not be because it is a prototype, but the non-slip mold feels a little weak.
In fact, the Academy has a lot of criticism that the mold is sharp but the volume is a little weak, which is not a problem for aero, but it's a bit exaggerated for the tank modeler, but there are many opinions that it's a bit exaggerated.
The clamps in the ovm are not just imitated like Tamiya, but they are able to reproduce the shape as much as possible. The thickness of the injection is also very thin, which makes it feel sharp.
The superstructure is completely separate from the fender, making it easy to develop other types.
Pulling out the fender entirely and reproducing the spring in one shot is a highly appreciated part. The real technology is to reduce the number of parts and make use of the details.
This runner mainly includes turret structures. When you open the hatch, you reproduce the cupolar interior that you see to some extent.
The pofu is very slightly reproduced.
MMZ20200722131514_2_5.jpg MMZ20200722131514_2_6.jpg MMZ20200722131514_2_7.jpg
The runner has a lot of parts, but it is part of the J-type and most lyunnecessary. In fact, the kit contains all the parts for the production of the L, M, and N types, as well as J. You can release variation kits by changing only decals, and modelers can create any format by using decals and overcoming the lack of documentation. Also, if you're a snowman, you'll catch your senses, but you'll also find a mix of assault cannon parts.
This runner includes possins, engine deck blackouts, and tow wires. Once you see two 50mm single-shot and long-shot, you'll see two tow wires and two engine black outs.
As I mentioned a while ago, this kit is showing this configuration because it can create all formats after type 3 j.
Type j You will use a single posin here.
MMZ20200722131514_2_9.jpg MMZ20200722131514_2_10.jpg MMZ20200722131514_2_11.jpg
In order to put out the F runner, i guess maybe f is not the Surchen mold used in the m, n type (it is already developed)
This runner contains a sporchket, roadwheel arm, suspension, idler wheel, and a semi-track part that is located on the floor.
This runner contains two identical ones,,
MMZ20200722131515_2_12.jpg MMZ20200722131515_2_13.jpg MMZ20200722131515_2_14.jpg MMZ20200722131515_2_15.jpg
The H runner consists of a load wheel, return roller, and track parts.
This runner contains four identical things.
The track is semi-curting, but it seems to be actually a connection.
The track details are good, but it's a shame that there are no holes in the guide pins.
Of course, if this track is used in Tank 3 or Assault Later, there's no problem with this blocked guide pin. But once in Type J, it's a shame.
Unfortunately, etching seldom got it until I was filming this introduction. I think we can only show it in a way.
The nickname reproduces the degree of engine grilling fairly simply.
Decals are domestic, and the quality of domestic decals has improved a lot nowadays, so there seems to be no problem.
We looked at the Academy's new 1/35 Scale 3 tank, type J.
It's a kit with easy assembly and proper difficulty. As modelers age, they tend to prefer products that use detail while minimizing parts rather than complex kits that are well-divided. Academy products seem to fit this trend.
We've seen that there are at least two or three formats available in different parts of the kit. The part configuration seems to have the assault grape in mind, so i guess maybe it could be released.
The consumer price of this product is 32,000 won and the domestic launch is September 2020.
http://mmzone.co.kr/mms_tool/mt_ ... z_media&no=5966
发表于 2020-7-25 00:21:04 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2020-10-8 13:16:49 | 显示全部楼层
爱德美新品(13531)-1/35 德国三号坦克J型 1942年北非战场海报
GMT+8, 2025-3-4 21:25
