模型网论坛
查看: 4784|回复: 11
Clearprop新品预告(CP72021)-1/72 米高扬 米格-23 MLD 鞭挞者
发表于 2020-7-5 18:29:19 | 显示全部楼层 |阅读模式
The new project from Clear Prop Models began with measurements of several real aircraft, which allowed us to develop reliable and accurate drawings formed the basis of our 3D model. Our new model CP72021 MiG-23 MLD will be produced as plastic kit in 1/72 scale. Also, the following modifications of lightweight MiG are planned: ML, MLA, MLDE and P.
Moreover, this summer, another new project of the famous aircraft, which is also designed on the basis of our own drawings, will be announced.
Follow our new posts!
 楼主| 发表于 2020-11-29 11:11:48 | 显示全部楼层
ClearProp新品预告-1/72 米高扬-古列维奇 米格-23ML, MLA, MLD和P 鞭挞者建模更新
127919956_198436701784690_884122077725483562_n.jpg.615d7c238ad888419b2d2c4133f1b303.jpg 128075089_399090271235339_492468770087854615_n.jpg.13220d668667d1fac12b74668072c844.jpg 128436762_423023492408728_4153990565509292528_n.jpg.6e74877908d4be2beda8386447461582.jpg 128469976_1919819304836096_2142835505731707437_n.jpg.441e01bd3e3417c81deb225588f637eb.jpg 128601910_821080148742970_7520746683687478852_n.jpg.b5396e01053bf5718c67ee82bc3c8712.jpg
128727662_430091608023507_3012949184393904563_n.jpg.d21d93a332c5e2bddd9fe2a550d6891e.jpg 128592042_3455116064557523_3145458135346816542_n.jpg.5b0ffce2d6c1099908312d8e797bb8f5.jpg
 楼主| 发表于 2020-12-1 21:15:06 | 显示全部楼层
128591518_2934050423544104_7601133869625321880_n.jpg 128385635_2934050716877408_3279935005417286451_n.jpg 128798855_2934050636877416_5253027454703478035_n.jpg 128858214_2934050686877411_7515360865892751955_n.jpg 128797484_2934050480210765_966990191055721167_n.jpg 129066956_2934050773544069_5371257267980884377_n.jpg 128169010_2934050576877422_8593428368199820419_n.jpg 128722279_2934050473544099_4239570357695930151_n.jpg 128385635_2934050530210760_1922524789104917281_n.jpg 128929494_2934050523544094_3935482484291810594_n.jpg 128603705_2934050620210751_6538002554642866133_n.jpg 128698669_2934050673544079_2499970135424397073_n.jpg 128836704_2934050583544088_4281373759589007976_n.jpg 128868836_2934050723544074_2120894070657993680_n.jpg
 楼主| 发表于 2022-4-28 18:48:52 | 显示全部楼层
Clearprop新品预告-1/72 米高扬 米格-23 ML/MLA 鞭挞者建模
MiG-23ML_MLA_01_web.jpg.bf106bafca6e30d1e45fab789ffb2661.jpg MiG-23ML_MLA_05_web.jpg.8ca2110eb8b4094de5eb71e1985216c0.jpg MiG-23ML_MLA_02_web.jpg.9d53a476237caabaf20cb3fe77abc07c.jpg MiG-23ML_MLA_08_web.jpg.952cbb353a6d73f60b8a69b39f32e029.jpg MiG-23-test-molds-1.jpg.88c0376e69a47be47baf8b18396ee52e.jpg
 楼主| 发表于 2022-5-20 20:17:47 | 显示全部楼层
Clearprop新品预告-1/72 米高扬 米格-23 ML/MLA 鞭挞者板件试模
IMG-5898.jpg.3bf77abe69a98f22415418848a3558c6.jpg 6C95D3E6-A9D3-4916-87C1-E17727BC7FB3.JPG.43e352dd2b34a816a3544c6622a937b2.JPG 59EE3340-876A-47F7-B21C-BF8E6DFBF675.JPG.e8cd1eb117c24f3839984b246c22fcb0.JPG D84D5A0D-6618-427C-893C-E63DD8F56F79.JPG.9e1f8144747460c3368626562ee589c8.JPG E238C731-8872-402B-A73A-DDA042E36D6F.JPG.405325946abd17068013fe7c1ff3152c.JPG IMG-5884.jpg.05ecba9ec89d0a0e643d201c161f6a1f.jpg IMG-5882.jpg.b59901a6f73b1e3cffed7f64ef18fa08.jpg
 楼主| 发表于 2022-8-13 19:20:11 | 显示全部楼层
Clearprop新品预告-1/72 米高扬 米格-23 ML/MLA 鞭挞者板件试模素组
198961869_.JPG.273dd89e603983a5b6bc890d36c2b106.JPG 1810430976_.JPG.21913405271a30b177935be6232b8d46.JPG 706124440_01.JPG.8019870e2841c16d23adf621047f4bea.JPG 1544603457_02.JPG.5ab78b15a2d8ab7f55c558dd926bac50.JPG 910536921_03.JPG.f500a49afd1371411517e894b871c6d2.JPG 1450264081_04.JPG.10bbeb4799c0553b5277b55909c84256.JPG 1881990207_7..JPG.7894ac062ded8a57732073d5e0d4ec32.JPG 1036638820_8..JPG.6683c0f78cd061e09e40336def3606da.JPG 481902999_9..JPG.a42b527b8ccdcaf0b8f2aa8130a83126.JPG 2043881209_10..JPG.32d84afae0993a4ff8a6fad8758de3e7.JPG 1151734519_11..JPG.473218f50aed37768c79a796f5f2c0b1.JPG 807052758_12..JPG.7d530e2a0a67663af52f54dbcb8e3163.JPG 1563084736_13..JPG.4c4b04d86b40206e61226bb64b1a74d9.JPG 930983541_14..JPG.12a334a896ab0ea12accd3d996e74261.JPG
 楼主| 发表于 2022-8-18 18:27:37 | 显示全部楼层
Clearprop新品预告-1/72 米高扬 米格-23 ML/MLA 鞭挞者板件试模素组更新
Greetings everyone!
The test assembly of the Clear Prop Models kit of Mig-23ML continues. At the current stage, all the main elements of the aircraft have been assembled, the model has been put on wheels.
It is necessary to give an explanation on the installation of the wing in the model.
As you know, all MiG-23 series aircraft have a variable geometry wing, which has 3 positions: 16 degrees, 45 degrees (or 33 degrees for MLD), 72 degrees. Most model manufacturers try to make it possible to change the angle of the wing, i.e. the wing in the model is most often made movable. Since this approach comes at the expense of copying (mechanization of slit closure is usually not provided for in models), we decided to go the other way. We offer to assemble the model in one of two options:
1) installation of the wing in the position of 16 degrees;
2) installation of the wing in the position of 72 degrees.
This approach to assembling the model will ensure maximum copying of all its elements.
The first test assembly is carried out with the wing set at 16 degrees.
Enjoy watching!
1149511494_15..JPG.afc58e15c505f536aa9b2323be601414.JPG 1563337006_16..JPG.03d532d6e571daca662d26ba9877b2ca.JPG 503395531_17..JPG.1c3803dd9f8122eba047a1a9fdc80d48.JPG 1879967135_18..JPG.48a013d2c34d519413c99baae68bb6ad.JPG 1230405045_19..JPG.c34f556a6109d58f136d3ccf747b38ff.JPG 1046765862_20..JPG.5cb0099a09ade18264229cc429a87271.JPG 590312609_21..JPG.ee25e1955c38e3a76e3dad993ca7c1a6.JPG 175577601_22..JPG.3005a87bb3052eeb1d5693a49d07700d.JPG 534068624_23..JPG.02f0fec5c6e247bded9607faf0f09fe7.JPG 1468768866_24..JPG.9cfd5038794c91f59c1c5b64085c39b5.JPG 511630270_25..JPG.9472fb21c994f742c92e4f05bbedb6e8.JPG 2143444585_26..JPG.cb73aacccecd8ad9db9d092d03c4a693.JPG
 楼主| 发表于 2022-8-29 19:59:34 | 显示全部楼层
Clearprop新品预告(CP72030)-1/72 米高扬 米格-23MLA 鞭挞者板件封绘素组更新
Greetings everyone!
The test assembly of the Clear Prop Models kit of Mig-23ML is over.
Enjoy watching!
mig231.png 27.JPG.42dfb248f81b94c6df765a1e120b833f.JPG 28.JPG.67d71a26bdd3239ae126c01c4f6fdfcf.JPG 29.JPG.3eebbe2fd2784b9e271073c4bcf68d2a.JPG 30.JPG.5300eac4cc0f2f955bc3ac1b70b2aab0.JPG 31.JPG.7c777a246e5ce03dbcfa5c150c020d0b.JPG 32.JPG.d72afae1cc922c4194f05090e9ddfb67.JPG 33.JPG.9fb9af0e9cb8e7890b8938e23fb735ec.JPG 34.JPG.f54d190791d1d010cd824e0185a56af5.JPG 35.JPG.3dc92ec6d6068f01c15557ece01fd156.JPG
 楼主| 发表于 2022-8-29 20:00:31 | 显示全部楼层
36.JPG.35862350ab3f8a05f8853e30fc206dba.JPG 37.JPG.6048a260077c3ab37867064802b3b284.JPG 38.JPG.2a542aa9b52cccf70fce0a8a776f2d51.JPG 39.JPG.dc3ea6a93a97ae963aa4b601d76527dd.JPG 40.JPG.345a0ee646ffa1d17d8fad39b688ebb7.JPG 41.JPG.a0d57b3cee36f9acacc8dc6a2903f1d1.JPG 42.JPG.4d199d53c2a93cf5c2465e537a8f5ee9.JPG 43.JPG.96413004826d2d2c434b93f97b41b768.JPG 44.JPG.d22be333d74bf79045292fa1b8088ecd.JPG 45.JPG.0e8b2588d117c5e082051fa27b8576b7.JPG
 楼主| 发表于 2022-8-29 20:01:46 | 显示全部楼层
46.JPG.b950761b335e9ceb283680068f6fa863.JPG 47.JPG.312202da966e4812151d2b2b5e715e7c.JPG 48.JPG.a7de91e7eeec2eb2574ecc8007d405ec.JPG 49.JPG.dfbd7c8c2b9ce0b39ad80c9a3ce9981e.JPG 50.JPG.eff355a7c6ce03cc30a033b8fc5d8036.JPG 51.JPG.5f1a59fb8f447b1811713ef2965a5d23.JPG 52.JPG.edf72b616318b9443e9b58ac60df12b9.JPG 53.JPG.cbe9a2a98ff6cbe607bfb4d8f22bf225.JPG 54.JPG.45b799688f8b39bcdba0ac7c0fa509f6.JPG 55.JPG.d928047201ca6aefc7e8329343c9e87f.JPG
GMT+8, 2024-5-8 03:38
