查看: 2965|回复: 0
ACE新品(72573)-1/72 Sd.Kfz.6/2半履带车搭载3.7cm Flak 36防空炮
发表于 2020-5-26 18:28:58 | 显示全部楼层 |阅读模式
3.7 cm Flak 36 auf Selbstfahrlafette Sd.Kfz.6/2 The 3.7-cm Flak 36 auf Selbstfahrlafette Sd.Kfz 6/2 with its 3.7 cm cannon can easily dispatch any aircraft given the circumstances. However, its gun (with APHE ammo) can also make it a very good improvised anti-tank vehicle if push comes to shove against an enemy tank.The 3.7 cm FlaK cannon was an AA gun capable of fully automatic fire at a rate of 120/150 rounds per minute up to four kilometres away. Multiple variants were made for the FlaK18/36/37/43. The Flak 36 was a simplified variant of a lak 18 with a lighter single-axle mount.
72573.jpg 1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 72567_a.jpg 72567_b.jpg 72570.jpg 72573_c.jpg 72567_tracks.jpg decal.jpg pe.jpg 72573_in1.jpg 72573_in2.jpg 72573_in3.jpg 72573_in4.jpg 72573_in5.jpg 72573_in6.jpg
GMT+8, 2025-3-4 11:53
