查看: 3012|回复: 2
Ammo-Mig新品-2020年5月上市新品
发表于 2020-5-26 18:13:23 | 显示全部楼层 |阅读模式
Dear friend,Today we want to share with you the "Illustrated Weathering Guide to WWII Late War German Vehicles" the latest addition to AMMO Publications, two new magazines ( The Weathering Magazine 30 - Abandoned & The Weathering Aircraft 16 - Rarities), new sets and auxiliary products that we are sure will be very interesting for you.
A.MIG-6015
Book, soft cover, 234 pages with more than 100 images in full colour
24,95欧元
One of the main problems for novice modellers and even many experienced hobbyists when facing the painting and weathering process is choosing not only the right effects they have to apply to each specific vehicle, but also the correct order of application.
The innovative format consisting of large colour prints will allow you to understand the painting and weathering process in a very clear and simple way, as well as the proper order of application of the different effects and techniques used for each camouflage pattern. Thanks to this unique presentation, you will be able to see how the appearance of the vehicle changes with the application of each step and how each step effects the next step and the final result.
Next to each colour profile, you will find a detailed description of each effect applied, the techniques required to make them, and the most accurate and easy to use products for each step. This illustrated guide is not a book about painting theory; it is a practical manual which will allow you to do one of the steps shown each day, allowing you to see how the finish of your model unfolds as your painting and weathering skills improve.
f3b0581b-4b2d-47f4-829e-8d43716aa59a.jpg 67825cb1-8a1b-437b-ab7c-eb2a30a8118f.jpg 53097683-2b9a-4975-9b0c-d548405e0c11.jpg ef36859b-642c-415e-8242-bf75b7f689f3.jpg 98690a9b-2fb8-4703-af30-5827b81b9f18.jpg f74daaed-dd9d-48c1-b044-6bedf3b698eb.jpg
Magazine, Soft cover, 72 pages in full color
The latest issue of your favourite magazine is a real treat for fans of extreme weathering with a focus on abandoned vehicles, aircraft, and Mecha. This wildly popular subject provides the opportunity to showcase multiple weathering effects accumulated in different conditions and varied environments over long periods of time. Abandoned machinery is a great canvas for learning and practicing to expand your knowledge of weathering effects and techniques including rust, chipping paint, and streaking effects.
A.MIG-4529    ABANDONED (English)    8,00欧元
 楼主| 发表于 2020-5-26 18:16:21 | 显示全部楼层
a5fe4129-a205-495d-a77d-e40ea4f7be46.jpg d0990607-8cf8-4f25-a6e5-74ca9ce11505.jpg 46c5ec9b-b8f5-4b2e-9ff2-fb2648118dd9.jpg c8a3557a-0166-468b-912a-1a8ad5909673.jpg f39edd32-b266-4a7c-a0b2-0b6b6c8839dc.jpg fa605c82-a475-4593-add9-b178aa11217e.jpg
The sixteenth issue of The Weathering Aircraft is available now! On this occasion, we will focus on unusual schemes and how to solve some of the problems often encounter ed when painting these interesting finishes. Quite often, the inherent difficulties of these camouflage patterns deter modellers from attempting to paint them. Knowledge of the amazing techniques demonstrated will be essential to applying a realistic finish to your models and will enable even a beginner to avoid a toy-like appearance. In this issue we will show you how to paint these rare aircraft, teach you what effects must be added, and demonstrate how to use the correct materials.
A.MIG-5216    RARITIES (English)    9,00欧元
e2634419-8808-48b0-aa79-e81bb6280c39.jpg 8a05b0b7-30e8-4275-a52c-0e7bacd05eb0.jpg 1230a416-e072-4781-9553-bb7c1dc1af1d.jpg
 楼主| 发表于 2020-5-26 18:20:28 | 显示全部楼层
a1243465-635f-4623-9fd4-8d05762fe652.jpg fc44a5ad-0ad9-4e42-aa37-bca692330878.jpg db58f369-1005-42b6-949f-59e3d2cd0e72.jpg faec3a57-d634-4a33-8ac3-7bf1ceffbe98.jpg 39f193b2-d872-4333-9915-b4145389b0b4.jpg
4fa28b9e-5e14-4182-963f-3893d6068a04.jpg cb1d55d0-05ee-42d2-902f-67a855dee5f8.jpg
A.MIG-7030
IDF UNIFORMS
Acrylic colours set for figures. 4 jars 17mL
9,20欧元
This set includes 4 colours for painting the infantry uniforms used today by the IDF (Israel Defense Forces). The colours have been selected through rigorous research of period uniforms, allowing you to accurately paint the base tones of uniforms, add highlights, and enhance details.
AMMO.F-503 Dark Olive Green
AMMO.F-504 Yellow Green
AMMO.F-506 Medium Russian Green
AMMO.F-509 Uniform Green Base
A.MIG-7229
WWII IMPERIAL JAPANESE ARMY SET
Acrylic colours set for WWII airplanes. 6 jars 17mL
13,80欧元
This high-quality acrylic paint set includes six accurate colours used to paint the camouflage schemes used by most of the aircraft to have served the Imperial Japanese Army (IJA) during WWII, including aircraft from both the early war years and the final campaigns of the conflict. This set resolves problems and doubts about mixing accurate WWII IJA colours, saving precious modelling time while delivering accuracy and ease of application. Among the aircraft that can be painted with this set are the well-known Ki-43 'Oscar', Ki-84 'Hayate' or Ki-61 'Hien', among others.
AMIG-0070 Medium Brown Dark Earth (BS 450)
AMIG-0191 Steel
AMIG-0258 IJA Grey Green
AMIG-0259 IJA Light Grey Green
AMIG-0260 IJA Kawasaki Green
AMIG-0261 IJA Nakajima Green
Product to thin acrylic paints in semitransparent coats
A.MIG-2042
TRANSPARATOR MATT 17 ML
2,30 欧元
A.MIG-2043
TRANSPARATOR MATT 60 ML
/>4,50 欧元
Water based thinner specifically designed for use with AMMO acrylics, also compatible with other acrylic brands as well. This product is necessary for painting semi-transparent acrylic coats with brush or airbrush easily without changing the quality and finish of paint while adding a completely matt finish. Transparator Matt is water soluble, odourless, and non-toxic
GMT+8, 2025-3-4 11:50
