查看: 3955|回复: 4
Ammo-Mig新品-2020年4月上市新品
发表于 2020-5-3 14:06:44 | 显示全部楼层 |阅读模式
Dear friend,
Today we want to share with you a batch of totally new products, including publications, sets and new decal sheets, that we are sure will be very interesting for you. All this products have real stock, so they are able to be ordered and sent immediatly.
76f037b8-8415-4ba9-ac48-7238bdaacf66.jpg f8d2e3fb-6dd4-415b-b5d0-289a01b926d4.jpg
Encyclopedia of Figures Modelling Techniques Vol.2
Book, soft cover, 112 pages in full colour
29,50
Volume 2 of the Encyclopedia of Figures focuses on the materials, procedures, and techniques best suited to painting and bringing a miniature to life. Once the elements of visual language such as colour, lighting, form, and texture have been learned from the first volume, it is time to engage the painting techniques that allow you to accurately represent each of these elements on any scale figure.
What is a binder? How do I dilute or thin the paint to make a glaze? What must I do to mix a highly saturated colour? Each material has particular characteristics and properties, understanding each will enable you to obtain the best results.
This book is structured around the three most widely used mediums: acrylic, oil, and mixed techniques that combine both, as well as the use of pigments and fillers. The use of the two most important application methods have also been taken into account: the brush and the airbrush, as well as alternating between each for a full range of realistic and dynamic effects. Closely linked to the procedures and tools are all the techniques that will grant each painter access to a wide range of resources and effects including gradients, glazes, washes, fresco casting, sketching, and a host of layered effects.
8c2d6b1c-5a69-4885-99e0-d92336b3db8b.jpg 9cc91b2a-b71a-40b6-91f4-2091d46ff99e.jpg 47752a61-4678-4d3e-9df9-064d2862c5d2.jpg 8da06dac-b049-42df-97f1-a4cd503ad369.jpg e9fc8d95-01fa-4443-b771-4536eee7c5f1.jpg fb6a663f-be61-499b-954e-c59fcec649f0.jpg e2cfa05a-720e-4e19-b427-e5ae7ddc8522.jpg 934e7e83-5e11-4cda-8859-dda78d1bb7b4.jpg
4fa28b9e-5e14-4182-963f-3893d6068a04.jpg 09c14d3d-138f-447e-a441-8a651c8ae4fa.jpg
A.MIG-7029
SPLINTER CAMOUFLAGE SET
Acrylic colours set for figures. 6 jars 17mL
13,80
This set includes 6 colours for the distinctively complex WWII German Splinter camouflage scheme. Originally designed in the 1930’s, this pattern was gradually adopted by a large number of units and used for various pieces of the uniforms until the end of the war. The colours have been selected through rigorous research of period uniforms, allowing you to accurately paint the base tones of the crew figures, add highlights, and enhance details. AMMO.F-532 Red Brown NEW
AMMO.F-535 Italian Green Camo NEW
AMMO.F-533 Dark Brown NEW
AMMO.F-536 Splinter Grey NEW
AMMO.F-534 Olive Green NEW
AMMO.F-537 Sunny Skintone NEW
A.MIG-7230
WWII IMPERIAL JAPANESE NAVY SET
Acrylic colours set for WWII airplanes. 6 jars 17mL
13,80
High quality acrylic paints designed to camouflage the vast majority of the Japanese Imperial Navy's aircraft flown during World War II including the iconic Zero, the D3A Vale, and any more. The wide variety of accurate tones used on Japanese planes makes this set an essential resource for enthusiasts of this popular subject.
AMIG-0046 Matt Black
AMIG-0263 IJN Medium Grey NEW
AMIG-0085 NATO Brown
AMIG-0264 IJN NAKAJIMA Dark Green NEW
AMIG-0262 IJN Ash Grey NEW
AMIG-0265 IJN MITSUBISHI Green NEW
These decals are of the highest printing quality and definition available, each marking is designed for maximum historical accuracy. For proper placement, we recommend using the special products Ultra Decal Set & Ultra Decal Fix (A.MIG-2029 and A.MIG-2030) for the best possible results.
 楼主| 发表于 2020-5-26 13:11:55 | 显示全部楼层
A.MIG-8062
1/72 T-54B Decals
Decals sheet scale 1/72nd
12,95欧元
This set of decals allows you to accurately apply nine different marking options of the T-54B in 1/72nd scale including vehicles from the Soviet Union, Poland, Czechoslovakia, Vietnam, and Afghanistan. These markings are specially designed for model kit A.MIG-8502 T-54B Mid Production by AMMO of Mig Jimenez.
 楼主| 发表于 2020-5-26 13:16:41 | 显示全部楼层
A.MIG-8060
1/16 Panzer I Ausf. A. Decals
Decals sheet scale 1/16th
11,95 欧元
This set of decals allows you to accurately apply 10 different authentic marking options of the Pz. I Ausf. A including: four German, one Chinese, and five from the Spanish Civil War. This set is recommended for the model Pz. Kpfw.I Ausf. A in 1/16th scale from TAKOM (TAKO-1008).
 楼主| 发表于 2020-5-26 13:17:42 | 显示全部楼层
A.MIG-8061
1/35 Panzer Divisions WWII Decals
Decals sheet scale 1/35th
11,95 欧元
This set of decals accurately includes all of the symbols and tactical markings used by German panzer divisions during World War II. With this set you will be able to place the correct symbols and tactical markings on your models of any German armoured or panzer division vehicle in 1/35th scale.
 楼主| 发表于 2020-5-26 13:19:41 | 显示全部楼层
A.MIG-6520
How to Paint
IMPERIAL GALACTIC FIGHTERS
Solution Book
Book, soft cover, 72 pages in full colour. Multilingual
9,95 欧元
The How to Paint Imperial Galactic Fighters Solution Book, that is released in four languages (Englsh, Spanish, French & German), is available individually from now.
SOLUTION BOOK is a simple and basic guide intended to help any modeller to easily achieve similar results to those shown in every example. It doesn′t matter a modeller is a novice or a more seasoned and experienced modeller.
Although we have chosen a Tie Advanced X1 as an example for this step-by-step guide, the same processes can be applied in exactly the same sequence and methods to any other Galactic Empire’s fighter, be it a Tie Fighter, Tie Interceptor, Tie Bomber, Tie Striker,Tie Defender, or even a Lambda-class shuttle. Now you just must grab your favourite model and start painting without further delay!
132259rr5dadtudodo1d61.jpg 132259nrmenpnsg1ai0nur.jpg 132259wj0sqql0ll77pxjy.jpg 132300tf1ck4z7ushmfjze.jpg 132300hsxplehhgjh7vhr9.jpg 132300nn835u38ksnnz1y1.jpg 132301btzzogz1gkrrmaad.jpg 132301tf3fmui7a6rj5jjj.jpg
GMT+8, 2025-3-4 11:21
