查看: 4199|回复: 0
牛魔王新品预告-1/48 Zlin教练机系列建模
发表于 2020-4-8 10:57:01 | 显示全部楼层 |阅读模式
Guys,
we are introducing the 1/48th scale Trener project today. I understand, this is very, very Czech or, better said, Czechoslovak project, not so much interesting for abroad modelers. However, it is good to know, that Treners were flown in many countries worldwide, in significant amounts. These trainers, which is a meaning of the name Trenér, served in France, Italy, Great Britain, as well as in Germany, Poland, Yugoslavia, Soviet Union and in many, many other countries. And, they serve even today.
About the project:
- You can see many versions here. Which is not all, because these version have even more subversions. Note most of these subversions served with two various engines, with Minor 6-III first, and latter were modernized using the M-137 engine. Both engines including cowlings are going to be included in all these single kits.
- These aircraft were and they still are very variable. So, if do you understand Trener variants, and if yes, you have all my respect, don′t warry if you will see anything incorrect in the pictures. All parts to build correct configuration will be included!
- All the small parts will be included in common parts frames, as in most other Eduard kits.
- The only exception is Z-526AFS, which is prepared to have exclusive set of unique frames.
001.jpg 002.jpg 003.jpg 004.jpg 005.jpg 006.jpg 007.jpg 008.jpg 009.jpg 010.jpg 011.jpg 012.jpg 013.jpg 014.jpg 015.jpg 016.jpg 017.jpg 018.jpg 019.jpg 020.jpg 021.jpg 022.jpg 023.jpg 024.jpg 025.jpg 026.jpg 027.jpg 028.jpg 029.jpg 030.jpg 031.jpg 032.jpg 033.jpg 034.jpg 035.jpg
GMT+8, 2025-3-4 08:43
