查看: 4511|回复: 1
牛魔王新品预告-1/48 阿维亚 S-199系列建模
发表于 2020-4-5 12:01:21 | 显示全部楼层 |阅读模式
S001.jpg S002.jpg S003.jpg S004.jpg S005.jpg S006.jpg S007.jpg S008.jpg S009.jpg S010.jpg
预计明年卫星
S-199 is designed to be released in two versions. This is the older one, with Bf 109G-10 Erla type canopy hatch. There is also undernose oil cooler with specific shape, used in first 25 produced S-199 shown on this picture.
This is late and standard version of the S-199, which was produced in more than 500 pieces. The modified canopy and the smooth bottom engine cowl are the main specific details of this aircraft. Our kit has the extra fuselage for each variant.
The early version of the nose, with specifically shaped oil cooler. Only 25 aircraft were equipped by this cooler. The final design of the nose of S-199, with the heat exchanger replacing the oil cooler.
One more picture showing the nose equipped with heat exchanger. There are two underwing cannon gondolas with MG 151 on this picture. Some S-199 were equipped by two MG 131 machine guns mounted in the wings, which will be an weapon option of our kit. One more view of the wing installation of the MG 131 in standard production aircraft. Standard S-199 with two underwing cannon gondolas with 2xMG 151 20 mm cannons. There is a new style separation of the wing and fuselage in S-199 as well as in Bf 109K-4. Also, there are separated position lights in the wing tips.
发表于 2020-10-29 16:58:59 | 显示全部楼层
谢谢分享! ! !
漏水測試
GMT+8, 2025-7-15 03:26
