查看: 8431|回复: 5
ABK模型新品预告(4004)-1/48 中岛 九零式二号舰载战斗机
发表于 2020-3-26 10:14:36 | 显示全部楼层 |阅读模式
https://www.abkmodels.cz/Nakajima-A2N2-1-48-d8.htm
_vyr_8_42004-Art-Box-18032020.jpg _vyrp11_8A2N2_3.jpg _vyrp12_8A2N2_1.jpg _vyrp13_8A2N2_2.jpg
 楼主| 发表于 2020-6-3 19:13:38 | 显示全部楼层
A.B.&K新品预告(4004)-1/48 中岛 九零式二号舰载战斗机更新
更新包装设计、板件试模与3款中岛寿发动机Ha-1含排气管树脂套件
1.a2n2finalboxartzfkux.jpg _vyrp12_8Plastic-Model-Frames-A2N2-1-48.jpg 3.4004_ba0k6n.jpg 2.4004_ab3kdk.jpg 4.4004_crwjr4.jpg 5.4004_dadkdx.jpg 6.pilons_1vskjt.jpg 7.pilons_2mikv3.jpg _vyr_14_48003RS1.jpg _vyr_15_48004RS2.jpg _vyr_16_48004RS3.jpg _vyrp11_1648004RS3_2.jpg
 楼主| 发表于 2020-8-29 18:32:35 | 显示全部楼层
A.B.&K hobby kits新品(4004)-1/48 中岛 九零式二号舰载战斗机上市
_vyr_8_42004-Art-Box-18032020.jpg _vyrp11_8mod_1.jpg _vyrp12_8decals-a2n2.jpg _vyrp13_8Test-frame_4004_A.jpg _vyrp14_8Test-frame_4004_B.jpg _vyrp15_8Test-frame_4004_C.jpg _vyrp16_8Test-frame_4004_D.jpg
 楼主| 发表于 2021-4-12 20:31:59 | 显示全部楼层
A.B.&K hobby kits新品(4004LE)-1/48 中岛 九零式二号舰载战斗机豪华限量版
https://www.abkmodels.cz/Nakajima-A2N2-Limited-Edition-1-48-d32.htm#detail-anchor-description
Nakajima A2N2 Limited Edition
Navy Type 90-II Carrier Based Fighter
Box contains complete kits, resin and photo etched parts
Ready to assembly scale plastic models kits
Material: plastic
Scale: 1/48
Wingspan: 195 mm
Fuselage: 129 mm
Plastic parts: 63
Resin parts: 54
Photo etched parts: 48
This kit is designed for advanced modellers and includes five plastic sprues, one of which is clear, resin parts of engine and armour, two scale figures of IJN pilots, two plates of photo etched for interior and exterior details and decals.
Resin parts include a detailed engine with holder and cover, drilled exhausts for both camouflage versions of the kit, one pair of hangers and detailed bombs, one pair of gun barrels and two figures IJN pilots.
Markings are provided for two different schemes.
Colored and detailed assembly guide will make the assembly process easy and enjoyable. And the box will serve as an excellent organizer which will be handy during assembly process.
_vyr_32_A2N2-Limited-Edition.jpg _vyrp11_32A2N2-LimitEd_web.jpg _vyrp12_32A2N2-set.jpg _vyrp13_32A2N2-exhaust.jpg _vyrp14_32A2N2-armour.jpg _vyrp15_32A2N2-LimitEd_pe2.jpg _vyrp16_32interior-A2Nx_work.jpg
 楼主| 发表于 2021-5-9 14:14:13 | 显示全部楼层
ABK模型新品(4004EE)-1/48 中岛 九零式二号舰载战斗机扩展版上市
https://www.abkmodels.cz/Nakajim ... -anchor-description
_vyr_35_A2N2-Extendeded-Edition.jpg _vyrp11_35A2N2-extended-edition_web.jpg _vyrp12_35A2N2-extended-edition_web_1.jpg _vyrp13_35PE-4001_4002.jpg _vyrp14_35PE4002_1.jpg
ABK模型新品(4004LE)-1/48 中岛 九零式二号舰载战斗机限量版上市
https://www.abkmodels.cz/Nakajim ... dition-1-48-d32.htm
_vyr_32_A2N2-Limited-Edition.jpg _vyrp11_32A2N2-LimitEd_1.jpg _vyrp12_322A2N2-set-of-parts.jpg _vyrp13_32A2N2-exhaust.jpg _vyrp14_322A2N2-armament.jpg _vyrp15_32PE-4001_4002.jpg _vyrp16_32PE4002_1.jpg
 楼主| 发表于 2021-8-31 20:20:54 | 显示全部楼层
ABK模型新品预告(4005)-1/48 中岛 九零式三号舰载战斗机
New boxing, this time under the new brand name: ABK Models - ref. 4005 - Nakajima A2N3
Source: https://www.abkmodels.cz/Nakajima-A2N3-1-48-d37.htm
_vyr_37_Nakajima-A2N3-Minoru-Genda_web.jpg _vyrp11_37Nakajima-A2N3-Minoru-Genda.jpg _vyrp12_37New-Camouflage-A2N3_1.jpg _vyrp13_37New-Camouflage-A2N3_2.jpg
GMT+8, 2025-7-2 23:04
