查看: 2260|回复: 0
田宫新品预告-2020年1月新品预告
发表于 2019-12-6 11:14:18 | 显示全部楼层 |阅读模式
R/C Models
 51623  1/10 Scale R/C Mercedes-Benz G 500 Body Parts Set
 51647  TRF420 Aluminum Front Direct Cups (2pcs.)
 51649  TRF420 Gear Differential Unit Set
 42351  TRF420 Center Pulley
 84438  1/10 Scale R/C Citroën 2CV Charleston Lightweight Body Parts Set
Kids
 18655  TOYOTA GR Supra (MA Chassis)
 15523  Low-Friction Plastic Bearing Set
 95557  HG Mass Damper Set w/Ball Connectors (Hex Weights/Carbon Plate)
 95523  Hi-Mount Tube Stabilizer Set (Clear Violet)
 95538  HG Aluminum Large Dia. Narrow Wheels II (2pcs.)
 95539  HG Lightweight 19mm Aluminum Ball-Race Rollers (Ringless/Purple)
 95542  Low Friction Large Dia. Slick Tires (Maroon, 4pcs.)
 70235  Rack & Pinion Gear Set
 10322  Basic Mini 4WD Car Box Clear Covers (3pcs.)
 95361  Festa Jaune Black Special (MA Chassis)
 95475  Gunbluster XTO Philippines Special Edition (Lil’s Hobby Center 50th Anniversary)
 95239  Carbon Reinforced Super FM Chassis Set
 95323  Super Hard Low-Profile Tire (Black)
Tools & Paints
 87202  40ml Square Bottle Holder
 74153  Craft Knife II
 82173  LP-73 Khaki
 82174  LP-74 Flat Earth
 82175  LP-75 Buff
69e53c99gy1g9m5xdwekgj20rs0kuwin.jpg 69e53c99gy1g9m5xe0ufxj20rs0kuwhr.jpg d1.jpg d2.jpg 69e53c99gy1g9m5xdqm9hj20rs0ku0tl.jpg 69e53c99gy1g9m5xdqqpqj20rs0kuq3x.jpg 69e53c99gy1g9m5xdrr1sj20rs0ku3zl.jpg 69e53c99gy1g9m5xdt643j20rs0kuq3t.jpg
GMT+8, 2025-3-3 17:29
