查看: 1803|回复: 0
田宫新品预告-2020年部分新品预告
发表于 2019-12-6 11:12:52 | 显示全部楼层 |阅读模式
Some upcoming 2020 Tamiya releases
R/C Models
47439 1/10 TT-02 Type-SR Chassis Kit
47443 1/10 Porsche 911 GT1 Street (TA03R-S chassis)
51635 1/10 VW Karmann Ghia Body Parts Set (M-chassis)
54897 Buggy Champ Ball Differential Set II
54932 T3-01 Aluminum Rear Bearing Holders
54933 T3-01 Rear Axle Weight Set
54944 CC-02 Aluminum Arm Pivots (A,B)
54945 CC-02 Low-Friction 6mm Ball Collars (18 Pcs.) LF
54949 TA07 Adjustable Ackerman Set
56554 Reinforced Axle Shaft Set for Tractor Truck
56555 Metal Display Antenna Set for Tractor Truck
Static Models
60328 1/32 North American F-51D Mustang Korean War
Kids
95547 Mini 4WD Portable Pit (Pink)
95550 TRF-Racer Jr. Black Special SP (MS Chassis)
Tools & Paints
69927 Spray-Work Air Compressor Advance w/Sparmax Airbrush SX0.5D
87203 Masking Tape/Plastic Sheeting (150mm)
GMT+8, 2025-3-3 17:23
