查看: 2814|回复: 0
Das Werk新品预告(DW35005)-1/35 2cm Salvenmaschinenkanone SMK 18-Typ 2
发表于 2019-11-12 18:02:13 | 显示全部楼层 |阅读模式
预计2020年一月底上市,推荐价格15.95欧元
Highly detailed breach and carriage assemblies
Working elevation and sight mechanism
Choice of optical or iron sights
Positionable stabilizer arms
Photoetched detail parts
Aside from the physical attributes evident in the existing prototype; caliber, number of barrels, overall dimensions, function of the elevation and traverse mechanisms, etc... very little is known for certain about the Salvenmaschinenkanone (SMK) 18 Typ 2.
Its 8 barrels were designed to fire simoultaneously, sending an enormous amount of metal into the air with each cycle of its massive bolt.
It would have been operated by a crew of 3-4 operators. The aiming mechanism controls were operated by the crewman in the right hand seat. The loader(s) would have been located on the rear platform.
Charging handles were located on either side of the breech block and were reachable from the rear platform.
The technological and manufacturing challenges encountered in getting all 8 chambers to succesfully and safely fire at a high enough rate to justify the adoption of this weapon over other proven weapons of the period relegated it to the role of future museum piece almost from the outset.
Rheinmetall Test Shooting Range, 1939
Unknown Unit, Berlin, 1945
GMT+8, 2025-3-3 04:35
