查看: 2982|回复: 2
MikroMir新品预告-1/72 阿姆斯特朗·惠特沃斯 A.W.52飞翼建模
发表于 2019-9-30 18:21:16 | 显示全部楼层 |阅读模式
 楼主| 发表于 2020-11-3 19:07:38 | 显示全部楼层
MikroMir新品预告(72-016)-1/72 阿姆斯特朗·惠特沃斯 A.W.52封绘包装
MikroMir is to release a 1/72 scale Armstrong Whitworth AW-52 experimental flying wing
Three aircraft, the A.W.52G glider and two jet-powered research aircraft, were built for the jet-powered six or four-engine flying wing airliner programme.
 楼主| 发表于 2020-12-20 15:27:12 | 显示全部楼层
MikroMir新品(72-016)-1/72 阿姆斯特朗·惠特沃斯 A.W.52上市
New models!
- 1/72 British experimental aircraft Armstrong-Whitworth AW-52. The model is equipped with 3D decal for the first time!
Now Available!
130876645_3751611418249900_1517235858682324904_o.jpg 131113023_3751610668249975_5329233336885935671_o.jpg 131088526_3751610761583299_2481826758942250873_o.jpg 130970610_3751611071583268_3793621568661331369_o.jpg
GMT+8, 2025-3-5 03:28
