查看: 5599|回复: 1
[陆军装备] [开盒简评]AMG新品(35-203)-1/35 BT-102"Spheroid"开盒
发表于 2018-10-24 13:32:26 | 显示全部楼层 |阅读模式
Friends!
This week we have decided to present to your attention a couple of reviews on products AMG Models. This company appeared quite a long time ago, but recently intensified its activities and began to produce a lot of interesting and high-quality models, showing an example of beautiful performance in the LND.
And first of all we want to consider a set with a model of a Fellow of the recent novelty from Miniart-Sharotankom BT-102  "Charroid ". The project of this fighting machine in reality was called  "Spheromobile " and was developed by V. M. Kuzmyin in the 1940th year and was quite detailed. The project envisaged Amfibijnost, and among all the other projects of spherical combat vehicles this was the most realistic.
The model is made in the classic armored scale 1/35, according to the technology of casting under low pressure. In addition to the plastic parts in the set includes photo and transparent details (more precisely-the detail of the ☺).
In a box of soft cardboard, decorated in the corporate style of AMG are the details of the model, decal and instruction.
On the end of the box are depicted alternative, including trophy, options  "Tank ".
The instruction looks original and stylish, in the form of yellening old drawing, instead of historical reference are given variants of colouring of model and the invented scheme of tactical structure of the unit, armed by these machines.
The assembly diagram is clear and detailed, not only the sequence of assembly is shown, but also examples of correct interlocation of details. There is not enough only instructions on colouring of small things.
The small decal is characterized by good print quality and a thin-lining. Problems with its application should not arise.
Photopoisoning well complements the detailing of the model, both interior and exterior. The etching is moderately thin and soft, except that the jumpers on which the details are kept quite wide and require stripping after cutting the detail.
In transparent plastic the glass of a headlight is given. It is smooth and convex. Ideally, it is better to change the headlight to the products of the company Elf.
The plastic model itself is grey, soft, easy to handle and glued. Casting clear, Litniki tokens, and not to say that it is lnd. There is no residue on the details as there are no unpleasant traces of the pushers.
Detalrovka such a small and outwardly simple model is good. The full interior is given, the hatch in the hull  "tank " can be opened.
The docking of the model, judging by the reviews in the network, good, but for the stable position of the model on the shelf to use the proposed in the set of  "shoes " or set it on the stand or to cut the bandage  "wheel " on the bottom and set the load (places for which In essence and not).
In general, the set of this Sharotanka came out interesting and original. The performed model is at a good level and will be a great addition to the set of Miniart. Well, the space for conversions is also very small. It is possible to replace a machine gun on DT, to add handrails or kokushi and etc. In general-a wide space for creativity!
Photo of the finished model-from the stand of the company at one of the Japanese exhibitions.
1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg 15.jpg 16.jpg 17.jpg 18.jpg 19.jpg 20.jpg 21.jpg 22.jpg 23.jpg 24.jpg 25.jpg 26.jpg 27.jpg 28.jpg 29.jpg 30.jpg
发表于 2019-2-17 21:43:04 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-11-26 00:48
