查看: 1746|回复: 0
续上:
 关闭 [复制链接]
发表于 2004-10-15 23:34:05 | 显示全部楼层 |阅读模式
603038800F-14A Tomcat  Version'94F-14A '94版熊貓戰機6030811000F-4J Phantom  II MarineF-4J 幻影II戰機60705900MI-24 Hind米格-24 戰機60706900SH-60 Sea HawkSH-60 海鷹式戰機60722700UH-1B HUEYUH-1B 戰機607431300Sukhoi SU-34 Striker FlankerSU-34 戰機607441300A-10A Thunderbolt IIA10-A雷電戰機607551000Messerschmit Bf109 E-4/7 TropBF109 E-4 戰機60759900JAS-39A Gripn最新多用途戰機610181200RAIDEN (Jack)雷電21型610271200A6M5C Type 52 ZeroA6M5C零521型610321800Spitfire Mk.I火岬MK1戰機610331800Spitfire Mk.Vb火岬MK5B戰機610341800Grumman F4F-4 WildcatF4野貓戰機610351800Spitfire MK.Vb Trop.岬火Vb戰機610361800Kawanish Kvofu Type11川酉水上戰機強風II型610371800Fock Wulf福武戰機610401800N.A.P-51D MUSTANG 8th AFP-51D野馬戰機第八隊610902500P-47D Thunderbolt"bubbletop"-47D 戰机    775021000Roney British BattleshipRoney 英國戰艦775041000Nelson British Battleship尼以遜英國戰艦775221300Prince Of Wales威以斯號戰艦780025000Yamato Battleship大和大戰艦78006400U.S.Navy Aircraft艦上機大戰艦8958638001/48 Focke-Wulf Ta183A Huckebein  w/KattenkrafFocke-Wulf Ta183A 戰機連領航車特別版工具、补料以下6折:70003350Pla-Plate Set S Size膠板套裝S700891300Walking Tyrannosaurus木工恐龍(暴龍)700935003-Speed Crank Axle Gearbox三速曲軸齒輪箱701042200R.Control  Bulldozer 線控履帶鏟泥車701153000RemoteControlled Forklift木工線控鏟車73004850Display Case C(1/24 Car)陳列盒 1/24車用730051000Display Case D(1/12Motorcycle)陳列盒 1/12電單車用730067800Display Case E 600x200x200mm陳列盒 600x200x200mm730106000Display Case H (for 1/48 & 1/32 Airplane)陳列盒 1/48,1/32飛機用73012600DisplayCase J (Φ125x95mm)Dome Type陳列盒 7301413000Display Case L陳列盒1/12 法拉利用74045900Modeler's Side Cutter (6/box)高級工具側剪鉗 (1盒6只)7452010800Spray Work Basic Air Compressor w/Airbrush厭縮泵連噴筆745221500Spray Work Painting Stand Set噴油用轉台87025400Ceramic Grease (12/box)潤滑油 (1合12支)87053250Tamiya Putty(BasicType)12/box基礎型不地 (1合12支)
GMT+8, 2024-11-30 07:14
