查看: 1957|回复: 0
续上:
 关闭 [复制链接]
发表于 2004-10-15 23:32:59 | 显示全部楼层 |阅读模式
50354 16T,1T AV Pinion Gear16/17齒 小齒輪50477 24/25T AV Pinion Gear24/25 小齒輪50541 Front Gear Case (TA01&02)A部品(前波箱)50795 Mini Cooper Racing Body迷你谷巴車殼51093 TB Evolution IV 46mm Suspension Shaft (4 pcs.) TV EVO4 46mm懸掛軸53155 Low Friction Aluminum Damper鋁低摩擦力油壓53157 Aluminum King Pins鋁殼柱53218 Hard Joint Cup (for Gear Diff)波箱硬接合杯53301 TL01 Stainless Steel Sus. ShaftTL01不绣鋼懸軸53322 TL01 Hollow Carbon Gear ShaftTL01中空炭化齒軸53331 TL01 Lightweight Chassis/FrameTL01 輕重量車架53534 3x8mm Titanium Countersunk Hex HeadScrew *53x8mm鈦六角螺絲頭53535 3x10mm Titanium Countersunk Hex headScrew *53x10mm鈦六角螺絲頭53627 TB EVO3 Reforced Diff.JointTB EVO3強化差速接合ø53649 TRF Screw (+)Driver LTRF十字螺絲批大53650 TRF Nut Driver (5.5mm)TRF六角批5.5mm53651 TRF Nut Driver (7.0mm)TRF六角批7.0mm53653 TRF Crub Driver (2.0mm)TRF 六角攪批(2.0mm)53654 TRF Crub Driver (2.5mm)TRF 六角攪批(2.5mm)53656 Tamiya Transmiter Bag田宮發射機袋53657 Tamiya Towel/Blue田宮毛巾藍色53658 Tamiya Towel/Black田宮毛巾黑色53664 TT-01 Aluminum Motor Heat SinkTT-01鋁摩打散熱 53665 TT-01 Spur Gear 55T/58T TT-01 正齒輪55/58齒53701 DF-02 Aluminum Damper SetDF-02 鋁油壓53702 DF-02 Spring SetDF-02 彈弓56010 RCTiger 1 Early w/Option老虎1型遙控坦克連發聲58302 TT01 Enzo Ferrari with ESCTT01 安素法拉利遙控車 連電子變速
GMT+8, 2024-11-26 21:35
