查看: 3921|回复: 2
各种工具和耗材的英文名
发表于 2014-7-6 02:11:23 | 显示全部楼层 |阅读模式
有些东西是词典查不到的。为了方便时差党们采购,我把常见的工具和耗材名称翻译翻译:
粘贴、切割和打磨类:胶水/粘接剂=cement/glue,快干胶=super glue,切割板=cutting mat,笔刀=hobby knife/modeler's knife/lancet,模型剪=precision scissors/scissors/side cutter,锉子=file,金刚石锉刀=diamond file,钻=drill,砂纸棒=sanding stick,水砂纸=wet sandpaper,磨砂膏=polishing compound,抛光布=polishing cloth,补土=putty,蚀刻片加工台=photo etch hold and fold workstation,胶棒=polystyrene rod/plastic beam,胶板=polystyrene sheet/ pla plate
涂装类:喷枪=airbrush,气泵=air compressor,稀释剂=thinner,水性漆/丙烯涂料=acrylic,珐琅漆=enamel,硝基漆=lacquer,涂料保存罐=paint mixing jar,遮盖胶带=masking tape,遮盖液=masking fluid,水补土(不知道为什么叫水补土,其实没人把它当补土用吧,都是当底漆)=surfacer/primer/surface primer,光油=varnish,消光剂=flat clear (clear就是透明,flat表示哑光,如果是gloss就是光亮了),水贴=decal,水贴软化剂=decal fix/decal softener,渍洗液=panel line accent color
楼下帮忙补充补充吧。有错请指正。
发表于 2014-7-6 12:24:11 | 显示全部楼层
好文。先精华了~楼主可以再完善一下么~
发表于 2014-7-7 08:41:35 | 显示全部楼层
不错不错 学习了
GMT+8, 2024-11-26 12:02
