查看: 4228|回复: 4
KPM新品预告-1/72 超马林 喷火Mk.1A和Mk.IIA/LR和Mk.V
发表于 2021-8-12 19:58:57 | 显示全部楼层 |阅读模式
box art - Mk.1A release September 2021
AZmodel is to reissue its 1/72nd F4F Wildcat in Grumman Martlet Mk.I
Two boxings expected in September 2021. Original AZmodel updated/cleaned mould  and new parts like the engine.
http://www.modelarovo.cz/superma ... vozavody-prostejov/
Spitfire-Mk-I-image2-DW-Q-bg1a-upr-V-scaled.jpg Spitfire-Mk-I-image3-KL-B-bg9a-V-scaled.jpg Spitfire-Mk-I-image3-WZ-S-bg22bb1-V-scaled.jpg Spitfire-Mk-I-image3-XT-A-bg9a-V-scaled.jpg
 楼主| 发表于 2021-10-11 20:19:00 | 显示全部楼层
KPM新品预告--1/72 超马林 喷火Mk.1A和Mk.IIA/LR和Mk.V包装和素组
- ref. KPM72261 - Supermarine Spitfire Mk.IA - Three-bladed Propeller
- ref. KPM72262 - Supermarine Spitfire Mk.IA - Commanders
- ref. KPM72263 - Supermarine Spitfire Mk.IA - Black and White
- ref. KPM72260 - Supermarine Spitfire Mk.IA - Wats Prop
Petr Muzikant, KP/AZ
Spitfire – the legendary British fighter is beautiful. Virtually all companies engaged in the production of plastic models have it in their production program. Four years ago, the company KP-Kovozávody Prostějov also launched its new model in the Mk.Vb and MkVc versions. We had to wait for the first machine gun version of the Mk.Ia to this day. The new Spitfire Mk.Ia model is just coming on sale and there is something to look forward to. The kit is made of metal molds and builds on previous versions. It is supplemented by a completely new frame with a new machine gun wing, different parts for versions with a double-bladed propeller. It also contains an unusual asymmetrically placed additional tank for the Mk.IILR version, which you can expect on sale soon as well. Beautifully clean transparent parts also contain a cabin of early versions. The new plastic parts made of medium-gray plastic are clean, finely negatively engraved without any defects. The inspection structure documented in a few photographs did not reveal any problem, a little putty will require the rear transition of the wing to the stern of the fuselage, where there is a small 0.3 „small crack“. I poured a thicker second of glue on it and cleaned the surface with a debonder. The whole model is glued amazingly simply, the practically perfect interior of the cockpit, including the relief holes in the bulkheads, will delight many fans of this beautiful machine.
The new kit belongs to the „top“ that can be found today on the theme of Spitfire in 1/72 scale. It will surely please all those interested in a simple, accurate and structurally comfortable model of this fighter legend."
100_0618.jpg 100_0619.jpg 100_0620.jpg 100_0621.jpg 100_0626.jpg 100_0627.jpg 100_1085.jpg
 楼主| 发表于 2021-10-11 20:21:19 | 显示全部楼层
100_1086.jpg 100_1087.jpg 100_1060.jpg 100_1062.jpg 100_1064.jpg 100_1065.jpg 100_1066.jpg 100_1068.jpg 100_1069.jpg 100_1071.jpg 100_1073.jpg 100_1074.jpg 100_1075.jpg
 楼主| 发表于 2022-1-27 19:48:58 | 显示全部楼层
KPM新品预告(KPM0276)-1/72 超马林 喷火 Mk.Ia-特殊涂装
ref. KPM0276 - Supermarine Spitfire Mk.Ia - special markings
KPM新品预告(KPM0277)-1/72 超马林 喷火 Mk.Ia-出口和埃及
- ref. KPM0277 - Supermarine Spitfire Mk.Ia - export & Egypt
二月上市
 楼主| 发表于 2022-3-10 19:19:49 | 显示全部楼层
KPM新品-1/72 超级马林 喷火 Mk.IIA"远离家乡"
Expected in March 2022 - ref. KPM0304
https://www.kovozavody.cz/produkt/spitfire-mk-iia-far-from-home/
GMT+8, 2025-2-6 16:51
