![](static/image/common/ico_lz.png)
楼主 |
发表于 2021-10-12 20:01:54
显示全部楼层
KPM新品预告-1/72 达索/道尼尔 阿尔法 喷气家族试模
One of the October novelties of the Kovozávody Prostějov company is the Alpha Jet jet training fighter. This elegant aircraft has gradually spread to many users around the world. From the modeling point of view in the 1/72 scale, this type was neglected for a relatively long time in the modeling „modern age“. Today, age-old „positive“ models from Airfix, Matchbox or Heller are available at times. There was also a model with already negative engraving from the Japanese Fujimi, but unfortunately it was out of scale in size and also the contour fidelity lagged much (see reviews on IPMS Deutchland and Britmodeller). So there was a little hole on the market… Now our new model from the „soft“ form, in a limited edition, is coming to the market. The kit is sprayed from a medium-gray, well-workable plastic with a fine negative engraving. The moldings contain basic parts for Alpha Jet versions A, E, MS.1 and MS.2, which will be gradually released in many boxed versions. Also in the frames we find four hangers, additional tanks and a suspended hull cannon. The kit is conceived according to today’s trends relatively simply, but it is not intended for beginning modellers. In a few photos, we bring you an orientation preview of the test construction, which is not entirely simple. Although the moldings are very nice and clean to look at, thanks to the technology, quite a lot of cleaning of the bearing surfaces and small parts is required. Proper cleaning really matters. In short, summed up, built… it is not a simple Alpha Jet, we will model it, we will not miss sealing and grinding, but the reward will be a nice and dimensionally accurate model.
