查看: 6405|回复: 8
KPM新品预告-1/72 霍克 暴风Mk.V/VI & Mk.II 6款封绘
发表于 2021-1-15 19:22:47 | 显示全部楼层 |阅读模式
1/72 - Hawker Tempest Mk.V/VI & Mk.II by Kovozávody Prostějov (KP) - box art - release in 2021
- ref. KPM0219 - Tempest Mk.V - Wing Commanders
- ref. KPM0220 - Tempest Mk.V - Clostermann
- ref. KPM0222 - Tempest Mk.V - 486.(NZ) SQ
- ref. KPM0226 - Tempest Mk.II - Export
- ref. KPM0227 - Tempest Mk.II/F.2
- ref. KPM0228 - Tempest F.2 - Silver Wings
 楼主| 发表于 2021-5-4 21:08:53 | 显示全部楼层
KPM新品预告-1/72 霍克 暴风Mk.V 4款涂装
Release in May 2021 5月上市 12,99欧
- ref. KPM0221 - Tempest Mk.V - Series.1
- ref. KPM0222 - Tempest Mk.V - 486 (NZ) SQN
 楼主| 发表于 2021-6-1 20:25:22 | 显示全部楼层
KPM新品预告-1/72 霍克 暴风Mk.V板件试模素组
 楼主| 发表于 2021-6-12 12:51:45 | 显示全部楼层
These days, the first traditional manufacturer, Kovozávody Prostějov, is launching the long-awaited new kit of the famous Hawker Tempest Mk.V fighter aircraft, in the most popular 1/72 scale. The new kit is made of metal molds using 3D technology. The parts are clean, without dents and defects with a very detailed fine negative engraving. Alternative parts enable the construction of Tempests of both production series. The control assembly showed only one small problem. It is necessary to lightly grind the bottom of the radiator on the sides during construction, because the halves of the engine did not fit together a bit. Otherwise, the construction went smoothly, as you can see in the attached photos.
At first glance, the model is far too „chopped“, which is not „in“ nowadays and many ordinary modelers disgust a large number of parts. There is beauty in simplicity, which is completely confirmed by our new „Emil“. The new Tempest is not easy to build in terms of the number of parts, but it is a tax that this kit is also the basis for other versions of Tempest. You can look forward to Tempest Mk.II and MK.VI, including all weapons. We will launch these versions this summer. Later, there will be a version of the Mk.I and other prototype versions, so that a number of Tempests are as complete as possible. We will launch the new Tempest in four boxes, including the classic – The Great Charles fighter Pierre Clostermann, so everyone will definitely choose. Models will be available at all good sellers and also on our e-shop. We will start shipping this model to foreign sellers within the next week.
100_0771.jpg 100_0772.jpg 100_0773.jpg 100_0774.jpg 100_0775.jpg 100_0776.jpg 100_0777.jpg 100_0778.jpg 100_0779.jpg 100_0780.jpg
 楼主| 发表于 2021-6-12 12:54:24 | 显示全部楼层
100_0781.jpg 100_0782.jpg 100_0783.jpg 100_0784.jpg 100_0785.jpg 100_0716.jpg 100_0730.jpg 100_0741.jpg 100_0751.jpg 100_0753.jpg 100_0754.jpg 100_0755.jpg 100_0757.jpg
 楼主| 发表于 2021-6-17 20:12:56 | 显示全部楼层
202763615_4167234600038039_2224747398786365982_n.jpg 202051507_4167234593371373_4248159856264239275_n.jpg 201540900_4167234783371354_67226172967896842_n.jpg 202677032_4167234510038048_5901134762540830422_n.jpg
 楼主| 发表于 2021-6-18 21:07:07 | 显示全部楼层
KPM新品-1/72 霍克 暴风Mk.V上市
Released
- ref. KPM0219 - Tempest Mk.V - Wing Commanders - https://eshop.kovozavody.cz/10517,cz_tempest-mk.v-wing-commanders-.html
- ref. KPM0220 - Tempest Mk.V - Clostermann - https://eshop.kovozavody.cz/10518,cz_tempest-mk.v-clostermann-.html
- ref. KPM0221 - Tempest Mk.V - Srs.1 - https://eshop.kovozavody.cz/10519,cz_tempest-mk.v-series-1.-.html
- ref. KPM0222 - Tempest Mk.V - 486 (NZ) Sqn - https://eshop.kovozavody.cz/10520,cz_tempest-mk.v-486.-(nz)-sq.html
 楼主| 发表于 2021-11-17 20:27:48 | 显示全部楼层
KPM新品预告-1/72 霍克 暴风Mk.V/F.6新包装
New boxing in November 2021 - ref. KPM0252 - Hawker Tempest Mk.V - At War
- ref. KPM0223 - Hawker Tempest F.6
- ref. KPM0224 - Hawker Tempest F.6 - Silver Wings
- ref. KPM0225 - Hawker Tempest F.6 - Over Egypt
KPM0252-box-768x538.jpg KPM0252-kamo-768x532.jpg KP-252-MK5-At-War.jpg KP-223-F6.jpg KP-224-F6-Silverwings.jpg KP-225-F-6-Over-Egypt.jpg
 楼主| 发表于 2022-1-27 19:59:28 | 显示全部楼层
KPM新品预告-1/72 霍克 暴风Mk.II/F.2三款
Expected in February 2022
- ref. KPM0226 - Hawker Tempest F.2 - export
- ref. KPM0227 - Hawker Tempest Mk.II/F.2
- ref. KPM0228 - Hawker Tempest F.2 - silver wings
KPM0226-box.jpg KPM0226-kamo.jpg KPM0227-box.jpg KPM0227-kamo.jpg KPM0228-box.jpg KPM0228-kamo.jpg
GMT+8, 2025-2-6 19:14
