查看: 13723|回复: 12
Arma Hobby新品预告(70038)-1/72 北美 P-51B/C 野马 专家版
发表于 2021-1-2 17:51:34 | 显示全部楼层 |阅读模式
We have a great pleasure to announce a kit you asked for a long time. The P-51 B/C Mustang release is planned in the second quarter of 2021. In the box, you can find parts to build both USAAF P-51B/C, RAF Mustang Mk III and reconnaissance F-6C. Kit features both regular and Malcolm Hood canopies moulded in open and closed positions. Optional are dorsal fin and different styles of inspection panels for an air filter. Under-wing stores included in the set are bombs, 110 and 75 gal fuel tanks.
First Expert Set edition will include photoetched parts, canopy/wheel masks and decals with six markings options (4 x USAAF and 2 x RAF).
Please review 3D renderings below. Your comments and questions are very appreciated. Design and kit content may change during production.
Kit is produced under license from Boeing. Boeing, P-51 Mustang and the distinctive Boeing logos, product markings and trade dress are trademarks of The Boeing Company.
Plastic model kit of the P-51 B/C Mustang aircraft, new tools, expert set with accessories.
Kit features parts needed to build 1/72 scale miniature of following variants: P-51 B/C, Mustang Mk III and F6C.
plastic parts
photo etched parts
decal with 6 marking options (4x USAAF 2x RAF)
masks for canopy and wheels
Produced under license from Boeing. Boeing, P-51 Mustang and the distinctive Boeing logos, product markings and trade dress are trademarks of The Boeing Company.
p51b_render_01.jpg p51b_render_02.jpg p51b_render_03.jpg p51b_render_04.jpg p51b_render_05.jpg p51b_render_06.jpg p51b_render_07.jpg p51b_render_08.jpg p51b_render_09.jpg p51b_render_10.jpg
 楼主| 发表于 2021-1-2 18:03:25 | 显示全部楼层
p51b_render_11.jpg p51b_render_12.jpg p51b_render_13.jpg p51b_render_14.jpg p51b_render_15.jpg p51b_render_16.jpg p51b_render_17.jpg p51b_render_18.jpg p51b_render_19.jpg p51b_render_20.jpg
 楼主| 发表于 2021-1-2 18:04:36 | 显示全部楼层
p51b_render_21.jpg p51b_render_ramkaA_01.jpg p51b_render_ramkaB_01.jpg p51b_render_ramkaT_01.jpg p51b_render_xx.jpg
 楼主| 发表于 2021-1-19 19:45:15 | 显示全部楼层
Arma Hobby新品预告(70038)-1/72 北美 P-51B/C 野马 专家版建模更新
Everything you wanted to know about Mustang from Arma Hobby and are not afraid to ask P-51b-cechy-blog.jpg
Posted by Marcin Ciepierski  Arma Hobby kits, Blog
Announcement of the P-51 B/C Mustang kit from Arma Hobby received significant attention from modellers on the Internet. It has met your expectations sent us in emails, blog and social media comments since over a year. You expressed your trust in Arma Hobby abilities to release the highest quality model of P-51B/C. You were also not afraid to ask questions about the Mustang kit, and there was one point you were primarily concerned, the leading edge of the wing. That was made wrong in many other companies kits. So let me answer your questions now!
Designing Mustang kit
Mustang kit design is a result of many months of research work on aeroplane construction. The project started from establishing correct general shapes and dimensions of the Mustang, based on factory documentation, and was made by Maciej Noszczak, well-known author of scale drawings you may know from many books. Then it was my turn, and I focused on airframe details and double-checking general shapes. Fortunately, Mustang B/C wasn’t changed too much during the production run, and the most challenging part of the kit design was to make dorsal fin fit easy for modellers.
Leading Edge from P-51-B/C and not from DYour main concern is the wing leading edge. I designed according to factory drawings of the P-51 B/C. The leading edge line breaks at the correct rib and with the correct angle.
We started with factory drawings.
We have double-checked factory drawings with aeroplane photos.
Here is the model leading edge
You can note leading edge drop towards fuselage bottom in the front view (it would be a reason for your concerns when looking at 3D pictures).
P-51 B/C Mustang production versionsIt is time to speak about production blocks. A very few changes appeared during the production of P-51B. We tried to include most of them in the model design in modellers friendly way.
A small panel after exhaust pipes in early P-51B versions. We will include it in photo-etched parts and decals according to modeller’s choice.
Inspection panels for an air filter are made in the most popular versions.
 楼主| 发表于 2021-1-19 19:54:15 | 显示全部楼层
Canopy is made in open and closed positions, both factory and Malcolm hood versions.
Oil breathing exit holes located below exhaust pipes are made in two positions and marked from the inside fuselage. You have to drill the one used on your markings variant.
Additional fuselage fuel tank introduced during the production run of the P-51 B/C is moulded as a separate part so you can configure radio section according to your choice.
Version without additional fuel tank you can model by filling a few panel lines on the fuselage.
Radio range-finder and dorsal fin can be assembled after cutting out their nest-holes. We put special attention to find an easy way to fit them in the model.
Reconnaissance version F-6C Mustang have camera windows to be drilled and trimmed from inside of the fuselage. Clear parts are included in the set.
And probably the most “important” feature in the long-range fighter, a pilot’s relief tube. It is moulded in the kit on the cockpit floor.
I hope this article has cleared up any concerns you might have had while waiting for this model. If something is still unclear – ask your question in the comments below.
 楼主| 发表于 2021-11-16 20:32:22 | 显示全部楼层
Arma Hobby新品预告(70038)-1/72 北美 P-51B/C 野马 专家版封绘涂装
https://www.armahobby.com/70038-p-51-b-c-mustang-expert-set.html
We are planning a release of the P-51B/C Mustang Expert Set in early December 2021. The kit will be available for preorders within a week when test shots will be available.
Kit includes all parts needed to build early and late versions of P-51B/C and F-6C Mustang. The decal sheet offers six markings options. Accessories included in the kit are photoetched parts and pre-cut masks.
Box Art 70038 P-51B/C Mustang™ Expert Set. Artwork By Piotr Forkasiewicz.
Markings options included in the kit:
P-51B-5-NA Mustang, 43-6315/AJ-A, "Ding Hao", pilot: Maj. James H. Howard MH, 356th Fighter Squadron, 354th Fighter Group, Boxted UK, April 1944.
P-51C-11-NT Mustang, 44-10816/278,   "Evalina", pilot: 1st Lt. Oliver E. Strawbridge, 26th Fighter Squadron, 51st Fighter Group, China, January 1945. Kit also includes Japanese markings of the captured aeroplane in 1945 (pilot Maj. Yasuhiko Kuroe).
Mustang III, KH516/WC-F, pilot: Kpt. Jerzy Mencel DFC, 309 Squadron Polish Air Force, shot down Me-262 jet fighter on 9 April 1945.
F-6C-1-NT Mustang, 42-03213/IX-H, "Azel"/"Boomerang", 162nd Tactical Reconnaissance Squadron, 10th Photographic Reconnaissance Group, Chalgrove UK. Aeroplane flown by several pilots during D-Day preparations in Spring 1944.
Mustang III, FB244/CV-V, 3 Squadron RAAF, Fano in Italy, April 1944. Aeroplane flown by several pilots mainly in ground support role.
P-51C-10-NT Mustang, 43-25045/C3-W, "Snookie", pilot: Lt. Edward T. Pawlak, 382nd Fighter Squadron, 363rd Fighter Group, France, July 1944.
258087145_4796443497052636_4667908012049985395_n.jpg big_70038-decal.jpg big_70038-photo-etched-parts.jpg big_70038-profile-1.jpg big_70038-profile-2.jpg big_70038-profile-2-bonus.jpg big_70038-profile-3.jpg big_70038-profile-4.jpg big_70038-profile-5.jpg big_70038-profile-6.jpg 258055800_4796434563720196_5914000509058828985_n.jpg
 楼主| 发表于 2021-11-29 20:26:22 | 显示全部楼层
Arma Hobby新品预告(70038)-1/72 北美 P-51B/C 野马 专家版板件水贴试模
big_p51b-ramka-b-001a.jpg big_p51b-ramka-b-002a.jpg big_p51b-ramka-b-003a.jpg big_p51b-ramka-b-004a.jpg big_p51b-ramka-b-005a.jpg big_p51b-ramka-b-006a.jpg big_p51b-ramkaA-foto-01a.jpg big_p51b-ramkaA-foto-06-fb.jpg big_p51b-ramkaA-foto-07a.jpg big_p51b-ramkaA-foto-08-fb.jpg big_p51b-ramkaA-foto-09a.jpg big_p51b-ramkaA-foto-10a.jpg big_p51b-ramkaA-foto-11a.jpg bokorysy-kompilacja.jpg p51b-kalka-01.jpg p51b-kalka-02.jpg p51b-kalka-03.jpg p51b-kalka-04.jpg p51b-kalka-05.jpg p51b-kalka-06.jpg p51b-kalka-07.jpg
 楼主| 发表于 2021-12-3 12:53:07 | 显示全部楼层
Arma Hobby新品预告(70038)-1/72 北美 P-51B/C 野马 专家版说明书
http://armahobbynews.pl/en/blog/ ... sembly-instruction/
70038_P-51_MUSTANG_BC_instrukcja-1-1.jpg 70038_P-51_MUSTANG_BC_instrukcja-2.jpg 70038_P-51_MUSTANG_BC_instrukcja-3.jpg 70038_P-51_MUSTANG_BC_instrukcja-4.jpg 70038_P-51_MUSTANG_BC_instrukcja-5.jpg 70038_P-51_MUSTANG_BC_instrukcja-6.jpg 70038_P-51_MUSTANG_BC_instrukcja-7.jpg 70038_P-51_MUSTANG_BC_instrukcja-8.jpg 70038_P-51_MUSTANG_BC_instrukcja-9.jpg 70038_P-51_MUSTANG_BC_instrukcja-10.jpg
 楼主| 发表于 2021-12-3 12:53:51 | 显示全部楼层
70038_P-51_MUSTANG_BC_instrukcja-11.jpg 70038_P-51_MUSTANG_BC_instrukcja-12.jpg 70038_P-51_MUSTANG_BC_instrukcja-13.jpg 70038_P-51_MUSTANG_BC_instrukcja-14.jpg 70038_P-51_MUSTANG_BC_instrukcja-15.jpg 70038_P-51_MUSTANG_BC_instrukcja-16.jpg
 楼主| 发表于 2021-12-4 18:39:21 | 显示全部楼层
Arma Hobby新品预告(70038)-1/72 北美 P-51B/C 野马 专家版制作
P-51 B/C Mustang cockpit
Marcin Ciepierski builds P-51 B/C Mustang from test shots
263067724_4849626858400966_6831340281563882051_n.jpg 263263795_4849626881734297_3521684812899377512_n.jpg
GMT+8, 2025-7-2 22:50
