Colours included:
A.MIG-0040 Medium Rust
A.MIG-0041 Dark Rust
A.MIG-0042 Old Rust
A.MIG-1002 Track Wash
AMA.MIG-1004 Light Rust Wash
A.MIG-1254 Streakingbrusher Rust
A.MIG-3005 Mediun Rust Pigment
A.MIG-3006 Light Rust Pigment
A.MIG-3008 Track Rust Pigment
A.MIG-3510 Oilbrusher Rust
A.MIG-3512 Oilbrusher Dark Brwon
A.MIG-8563
STANDARD SANDING STICK
This sanding stick provides 4 different grits: 180/320/600/2000, ideal for any sanding job covering a wide range of applications. Each grit surface area is easily identifiable by colour. The flexibility of the material easily conforms to any shape including rounded surfaces. The coarser grit range can be used on a full range of materials including resin, metal, wood and, of course plastic. The 2000-grit area will allow you to eliminate small defects and blemishes, even on clear plastic parts or previously painted surfaces.
A.MIG-8564
MULTIPURPOSE SANDING STICK
This sanding stick provides 6 different grits: 150/240/320/600/1200/2000, ideal for any sanding job covering a wide range of applications. Each grit area is easily identifiable thanks to their different colours. The flexibility of the material easily conforms to any shape, including rounded surfaces. The coarser grit range can be used on a full range of materials including resin, metal, wood and, of course plastic. The 2000-grit area will allow you to eliminate small defects and blemishes, even on clear plastic parts or previously painted surfaces.
1,95 欧元
A.MIG-8565
LARGE SURFACES SANDING STICK
This sanding stick provides 3 different grits: 320/600/4000, ideal for any task that requires a very smooth finish. Each grit area is easily identifiable by colour. The flexibility of the material easily conforms to any shape, including rounded surfaces. The coarser grit range can be used on a full range of materials including resin, metal, wood and, of course plastic. The fine 4000-grit polishing surface will allow you to refine and perfect clear plastic parts or previously painted surfaces. For the best results, polish clear parts and previously painted surfaces as required, always gently polish to remove the glossy finish on decals.
1,75 欧元
A.MIG-8560WEDGED DROP SPONGE2,25欧元
A.MIG-8561ROUND SPONGE 1,25 欧元
A.MIG-8562TEARDROP SPONGE1,50 欧元
These sponges have been especially designed to apply pigments and washes. The soft material facilitates working on delicate models without damaging the paint or surface details, and to remove excess pigment and washes very easily. We recommend using this finishing product over a satin or glossy surface. The sponges are available in three different shapes to better suit a variety of modeller′s needs. You can also cut them into unique shapes with scissors or a hobby knife for specific applications.
A.MIG-8080
1/35 SCALE TIGER TOOL CLAMPS
Can be used on Tiger, King Tiger, Jagdtiger, and Sturmmörser tanks in 1/35th scale, ideal for any kit brand.
Made of resin using state-of-the-art 3D technology.
Assemble with the adhesives Ultra Glue A.MIG-2031 and Slow Dry Cyanoacrylate A.MIG-8013.
11,95 欧元
A.MIG-8081
1/35 SCALE PANZER IV TOOL CLAMPS
Can be used on all Panzer IVs in 1/35th scale, ideal for any kit brand.
7,95 欧元
.MIG-8082
1/35 SCALE KING TIGER ENGINE COVER GRILLES
Can be used on King Tiger and Jagdtiger tanks in 1/35th scale, ideal for any kit brand.
7,95 欧元
