查看: 3082|回复: 1
MikroMir新品预告-1/48 容克 W.34. W.33, W.46, K.43
发表于 2020-6-4 18:44:22 | 显示全部楼层 |阅读模式
MikroMir is intending to release the single engine Junkers W.34. W.33, W.46, K.43 in 1/48 scale
Obviously early days in the design process, but never the less exciting to have the quarter scale Junkers W/K series in the works
 楼主| 发表于 2021-11-3 20:15:44 | 显示全部楼层
MikroMir新品(48-019)-1/48 容克斯 W.34hi上市
https://ua-hobby.com/products/1-48-junkers-w-34hi-mikromir-48-19
mm48019_1024x1024@2x.jpg mm48019-2_1024x1024@2x.jpg mm48019-3_1024x1024@2x.jpg mm48019-4_1024x1024@2x.jpg mm48019-5_1024x1024@2x.jpg mm48019-6_1024x1024@2x.jpg mm48019-7_1024x1024@2x.jpg mm48019-8_1024x1024@2x.jpg mm48019-9_1024x1024@2x.jpg mm48019-10_1024x1024@2x.jpg
GMT+8, 2025-2-6 21:49
